Tractor Talk Discussion Forum
1175 Case 3 point lift problems
kz9d
01-18-2008 17:25:31
Just bought a Case 1175. I put a blade on the 3 point left and it will not lift execept when it is ai full throttle and only about 2in. When I throttle down the lift lowers.
bradley martin
01-19-2008 08:43:58
 Re: 1175 Case 3 point lift problems in reply to kz9d, 01-18-2008 17:25:31
If you check the archives on the Case board you will find several past discussions regarding this problem with the 70s series.
bradley martin
01-19-2008 05:22:09
It is also possibly a problem w/ releif valve, but you need to check your pressure at the remotes to start narrowing it down.
kz9d
01-19-2008 06:18:01
 Re: 1175 Case 3 point lift problems in reply to bradley martin, 01-19-2008 05:22:09
I have not put a gage on the remotes yet. When I move the remotes the trator loads up and I can tell they have pressure.
bradley martin
01-19-2008 02:37:44
Have you checked the pressure at the remotes? That is your next step. If pressure at the remotes is good, you likely have a problem in the valve. If there is low pressure at the remotes, odds are the pump is kaput. Good luck.
