Tractor Talk Discussion Forum
12volts
fire50
01-10-2008 06:54:57
Is there a 12v conversion kit for a Farmall A?
Mark W.
01-10-2008 07:19:10
 Re: 12volts in reply to fire50, 01-10-2008 06:54:57
Be sure to replace any 6 volt lights that you may have and not to crank on the starter too long for risk of burning it up. It doesn't happen often can.
Dan-IA
01-10-2008 07:15:42
Who needs a conversion kit? all you need is a V-belt, an alternator, and a ceramic resistor you can get at your local automotive store. The resistor goes inline with the coil if I remember right. Take the generator off, modify the mounts just enough to put the alternator on there, and you're done. Easy.
rrlund
01-10-2008 07:24:12
 Re: 12volts in reply to Dan-IA, 01-10-2008 07:15:42
Or...you could just use a 12 volt generator and not have to modify anything.
Dan-IA
01-10-2008 07:16:24
Oh, a 12v battery would be good too. But that's stating the obvious. :)
rrlund
01-10-2008 08:13:41
 Re: 12volts in reply to Dan-IA, 01-10-2008 07:16:24
Yup,can't forget the most important part. :)
