Tractor Talk Discussion Forum
Which is the best No till drill?
Suds in Ohio
01-09-2008 17:42:33
I am currently looking at getting a used no till drill, probably a 15ft. I have borrowed a buddies JD 750 and now 1560 drill many a times and seem to like it. Only problem I see with them, if I run into wetter ground it will really sock'em in. I rented a Case IH drill w/Yetter cart for my winter wheat and though it did a alright job, but did not quite like how long the unit was for my headland turns in comparison to JD. I am also looking at Great Plains, but have zero experience with them and have not found any with markers.
Anyone have any feedback on them?
Thanks,
Suds in Ohio
CumminsMan
01-10-2008 08:23:50
 Re: Which is the best No till drill? in reply to Suds in Ohio, 01-09-2008 17:42:33
Great Plains also makes a good unit, better than the JD in wet ground, but not as good in extremely dry hard conditions. I have to ask why you need markers? You can almost always tell where you have been.
Suds in Ohio
01-10-2008 13:11:13
 Re: Which is the best No till drill? in reply to CumminsMan, 01-10-2008 08:23:50
Oh, I guess the only reason I need markers is I pride myself on how straight I drive planting. My buddy's JD drill that I always use has markers and I have grown accustom to them. When I rented the Case IH drill without markers, it looked like a drunk person planted my field when the crop came up. I am sure that if get one without, I will be able to catch on and plant straight.
steve in wi
01-09-2008 19:24:35
We run a 750 drill have had nothing but good luck with it.As far as markers go,they slow you down a bit on the head lands .I believe they hook up on your other hyd lever and slow to pick up. Always had great success just following my last pass ,very little overlap.Steve
Keith in NW MO
01-09-2008 18:13:37
third party image
third party image
There is only one JD go with the 1560
doesnt
01-09-2008 20:56:46
 Re: Which is the best No till drill? in reply to Keith in NW MO, 01-09-2008 18:13:37
thats a black land drill.
Suds in Ohio
01-09-2008 19:04:40
Nice pics Keith! It looks like you are using it in tilled ground without markers. Do you use your good eye drilling, or do you have GPS? What are you pulling that drill with, 4640? I have the most experience with Deere's and like them a lot.
Keith in NW MO
01-10-2008 09:13:14
 Re: Which is the best No till drill? in reply to Suds in Ohio, 01-09-2008 19:04:40
We no-till most of our ground, I would like markers but don"t have them. The tractor is a 4430 which makes a good match for this drill. I helped a neighbor drill 200 acres of sod this past spring and they used a Great Plains, you could tell during harvest the difference. He estimated the yeild difference to be over 10 bu. per acre. Advantage to the JD and that"s from a Great Plains owner.
Larry59
01-09-2008 18:19:05
 Nice pics..?? in reply to Keith in NW MO, 01-09-2008 18:13:37
Nice pitcures.. so that is a drill he is talking about.. just what does the drill do ? Thanks
Suds in Ohio
01-09-2008 19:09:47
 Re: Nice pics..?? in reply to Larry59, 01-09-2008 18:19:05
That drill is able to plant without any tillage using hydraulic down pressure to the gangs. Reduced tillage means less trips across the field reducing wear and tear on tractors and less fuel consumption.
Larry59
01-09-2008 19:39:10
 Re: Nice pics..?? in reply to Suds in Ohio, 01-09-2008 19:09:47
Thanks for you reply.. Learn something new. I just had thought a drill was a drill.. like for post holes only on a tractor. Take care..*S
