Tractor Talk Discussion Forum
165 serial number
Rob Marano
01-09-2008 12:54:55
I'm having trouble finding a serial number on my 165. The numbers stamped on the transmission, engine and back-end don't correspond to any serial numbers listed.
Can someone show me where to find a serial number as I would like to replace the clutch and need a serial number to do so.
2x4
01-11-2008 11:44:05
 Re: 165 serial number in reply to Rob Marano, 01-09-2008 12:54:55
if its a gray machine the numbers will be on a plate under your right foot, on side of transmission, under brake pedal.
2x4
01-11-2008 11:44:01
Don-Wi
01-09-2008 13:49:42
Yup, like MF Poor says, if it's there it's right on the dash panel, in front of the shifters on the bottom of the panel.
Donovan from Wisconsin
MF Poor
01-09-2008 13:25:24
It SHOULD be on a small metal plate (approx. 2" X 3") located on the sheet metal that encloses the battery, below the steering wheel, just in front of the shifter levers. It SHOULD be there, held on by 4 small screws.
