Tractor Talk Discussion Forum
What is the best way to tarp a tractor?
Aaron Ford
01-09-2008 09:33:20
Last year I made the mistake of tarping my tractor completely. Like to the ground, held down and sealed with cinderblocks. That was a dismal idea as every day it rained underneath the tarp and cost me many more hours of paint prep than that what would have been needed if I had just left it in the rain/snow.
I am not as foolish as to think that my new shifter boots and seals will hold out a seasons rainfall. I would also like to keep the sun off my new paint and gauges as much as possible. But how on earth do you tarp the thing?
I had an idea of wrapping the tarp around the main section of the tractor or perhaps halfway down the wheels. I am sure that airflow is the key, but remain confused as the best way to do it. I welcome all responses except for the garage idea. Woman almost served me walking papers for doing that last time. Pulled it in in December and took it clear apart.... Brings it up everytime I start a new project.
Thanks in Advance,
Aaron
Jeff-oh
01-10-2008 10:01:35
 Re: What is the best way to tarp a tractor? in reply to Aaron Ford, 01-09-2008 09:33:20
I tarp mine like a camping rain fly. I put the tarp over the tractor then use 8" gutter nails to hold the corners out. With strings.
I found that the wind will cause the tarp to "sandpaper" the paint on the ridges and corners. Mine is not a restor paint job.
But to fix that make some stand offs to keep the tarp off the paint. I have also made a mini structure out of 1" by 2" fairing strips. This tarp frame is set over the tractor and the tarp is draped over that. The ridge piece is only 4" higher than the tractor and the frame is light enough to pick up.
Jeff
in-too-deep
01-09-2008 13:18:07
I would try to keep the tarp from clinging to the sheet metal directly. With that hood of yours, it could be draped pretty tightly, and moisture will be trapped in between the plastic and steel. You just can't beat a roof for protection.
Aaron Ford
01-09-2008 12:40:29
You may be right. I purchased a temporary shelter (big white vendors tent) for assembly and painting and still take it to car shows, but as a permanent structure, it lacks much. Last nights wind storm had me afraid to look out to see the damage. It held, but I know better than to trust it. I am thinking of a 12x12 tarp that would not reach the ground but be bungeed into position reaching half way down the wheels. Whad'ya think? BTW, it is a Massey 65.
Aaron
third party image
Verniee
01-09-2008 12:47:59
 Re: What is the best way to tarp a tractor? in reply to Aaron Ford, 01-09-2008 12:40:29
Wow! Now that's a nice tractor. Did you restore it yourself?
Aaron Ford
01-09-2008 13:19:11
 Re: What is the best way to tarp a tractor? in reply to Verniee, 01-09-2008 12:47:59
Sure did, Just finished last fall. Well nothing is really finished... This was the eBay picture.
third party image
Aaron
Verniee
01-09-2008 13:22:26
 Re: What is the best way to tarp a tractor? in reply to Aaron Ford, 01-09-2008 13:19:11
Impressive indeed.
Mike (WA)
01-09-2008 12:17:39
Best way I've found, if you can't build a little frame-work or get one of those tarp-over-pipe frame "portable garage" things, is to get a tarp a bit bigger than it would take to cover just the tractor- lay it over the tractor, kind of like pitching a tent with the tractor being the ridge-pole. Drive a steel fencepost about a foot out from where each corner is, when you hold the corner about 2 feet above the ground. Use twine to anchor each corner. By keeping the post about a foot away from the corner, you can use the twine to put a little stretch on the tarp. Now, take the tarp off, and drive the tractor ahead or back so you can put a piece of black plastic (or another tarp) down, about the size of the rectangle formed by the fenceposts. Drive the tractor back onto this groundcloth, and re-install the tarp. Then go in the house, and let wife berate you about the ugliness of the whole lash-up.
ScottyHOMEy
01-09-2008 12:03:38
A weighted tarp on the ground will limit the rising moisture to some degree. With or without that, it's best to rig your tarp to allow air to flow. You might want to try weighting your tarp with two-liter soda bottles, that can hang above ground level to let some air underneath. Up here where we have a winter, you fill the bottle about 3/4 full, squeeze the air out before putting the cap on. This allows the bottle to expand when it freezes without busting and causing you to lose your ballast weight when the bottle thaws back out.
You don't say what you have for a tractor, but if you can get your tarps in dimensions that let you rig them so that there's some opening at the top or the high spots (like below the seat but above the deck) that can help vent any moisture coming up from the ground.
Billy NY
01-09-2008 10:01:51
That trapped moisture that gets in a tightly tarped tractor or other piece of equipment that is wrapped up, and really accelerates the rust, my neighbor did that with garage kept snow blower and boy did the paint really bubble up and flake off the old snapper snowblower, it looked new when I helped him pick it up, now it looks ready for the scrap heap. Definitely needs to breath under a tarp and even then, there will still be moisture.
I tarp my tractor before a storm, then take it back off again, I skirt the bottom, but leave a space for the air to get under, have to be careful how you do that, the wind will blow it off if not tightly secured. In short tarping a tractor can be a pain in the @ss and be more problematic than it's worth, better left out without one. I try to cover the new tires up when the sun is out, just becomes a hassle, a roof is much better. I've set the stage to add another garage bay, have to finish the roof on a 20x32 pole barn with a shed to one side, won't be dealing with tarps and sheets of plywood much longer, everything will be under a roof.
Can you build a small but rigid out building or a car port shed off your garage, aesthetically pleasing or matching what you have existing? If what you have is just a small - mid size utility tractor, the cost should be minimal, even with todays costs, just to get a roof over it. I don't like the fabric covered pipe type of tent like buildings myself, really have to contend with securing them down in the wind etc. My friend took some left over rough cut pine and corrugated metal roofing, and built a small but functional wood a-frame on a short knee wall for his ford 640, it cost less than $50. With some imagination you could possibly make something similar, including some matching finishes so it fits in with what is existing, thenm it will be under a roof at least, lot better an much less hassle than a tarp.
IH2444
01-09-2008 09:58:04
Put plastic on the ground under the tractor / cover tarp. It will keep the moisture in the ground from rising up under the covering tarp and being trapped there.
