Tractor Talk Discussion Forum
tractor year
Fire50
01-08-2008 15:41:58
I have a Farmall A #FAA-115194 the service manual I recieved with it states it"s a "47" but was told by so called "Farmall guru" that by the ser.# it"s a 1945. What I"ve found it"s a 47 with a low ser. #. Thanks for the help!
Hugh MacKay
01-08-2008 16:18:14
 Re: tractor year in reply to Fire50, 01-08-2008 15:41:58
How could you have a 47 with an early serial number. Is there something that seriously makes you believe this? Serial numbers don't lie unless they've been changed. If you believe that is the case check out casting date codes, those can't be changed.
lzybull
01-08-2008 16:07:49
Farmall Model A, AV, B and BN
Year Starting Serial Number 1939 501 1940 6744 1941 41500 1942 80739 1944 93690 1945 113218 <<<
1946 146700 1947 182964 The Serial Number is located on the seat bracket on the left side
here you go. glenn
IaGary
01-08-2008 16:01:44
Its a 1945 by the serial number.
What makes you think it is newer?
Gary
