Tractor Talk Discussion Forum
64' Ford 4000 Diesel 4 cyl.--electrical
Bob I
01-08-2008 05:44:25
A friend is rebuilding a 4000 that he has- We can"t determine whether it is a 6 volt or 12 volt system. We don"t have the original battery and none of the serial #"s are any help. We have called the local Ford dealer and they weren"t any help. Does any one know if the 64" was 12 volt or 6 volt or both?
john in la
01-08-2008 17:17:06
 Re: 64' Ford 4000 Diesel 4 cyl.--electrical in reply to Bob I, 01-08-2008 05:44:25
All ford diesels are 12v.
Here is the correct orginal wiring diagram for your tractor.
third party image
Fordfarmer
01-08-2008 06:59:12
All Ford gas tractors prior to 1965 were 6 volt from the factory. (with the possable exception of the 6000 gassers- I'm not sure about them.) All Ford diesels, regardless of year, are 12 volt.
Balatonm
01-08-2008 06:10:41
It should be a 12 volt system, most of the tractors i've seen built after 1962 at least have the 12 volt system. You could also just wire it for a 12 volt system if you have the tractor all apart.
Wayne in Tx
01-08-2008 06:09:10
All the ones I have seen are 12 volt --- my manual states that is the way they came from factory.
PS: I reserve the right to be a 100% wrong and I am sure that the experts will let me and you know.
