Tractor Talk Discussion Forum
Marvel TSX-363 carb
cdm
01-05-2008 16:53:40
Can anyone tell me what a Marvel TSX-363 carb fits? It looks very similar to the carb on may JD 430. Thanks in advance
dobber
01-05-2008 23:02:14
 Re: Marvel TSX-363 carb in reply to cdm, 01-05-2008 16:53:40
Your JD 430 used a TSX-688 if gasoline or TSX-689 if all fuel and would probably have different venturi and jets. Marvel Schebler catalog 1-400 shows TSX-363 fit Oliver 66HC & 77HC but super models used different numbers. That's the only Olivers it shows to have fit originally but suppose you could substitute it anywhere with enough monkey brains or banana grease? :)
old
01-05-2008 18:00:51
Well from my catalog it fits an Oliver 66, S66, 77 and 660 and probably a few more.
J Schwiebert
01-05-2008 19:06:28
 Re: Marvel TSX-363 carb in reply to old, 01-05-2008 18:00:51
I don't care what your catalog said. The 660 models use a larger venturi and they will not bolt up.
old
01-05-2008 21:31:14
 Re: Marvel TSX-363 carb in reply to J Schwiebert, 01-05-2008 19:06:28
What can I say other then I can only go by what my books say and if they are wrong its not my fault but theres.
eeeeeeeeeeeeeee
01-05-2008 17:14:53
oliver 66 and 77
PH
01-05-2008 17:11:40
Thats what my Oliver 77 has on it. I'm sure there are more.
