Best way to Prevent Tire Checking and Cracking
skyharborcowboy
01-02-2008 15:03:51
What is the best way to prevent a set of tires from Checking and Cracking? Do any of the commercial tire products such as Armour All or any other tire dressing help?
Thanks,
Joe
Steven f/AZ
01-03-2008 06:12:17
 Re: Best way to Prevent Tire Checking and Cracking in reply to Mike M, 01-02-2008 15:03:51
msb said: (quoted from post at 22:43:38 01/02/08) Give them a light coat of silicone spray every 6 months.
I use Prestone Silicone spray on my door seals to keep them supple and crack-free... never tried it on tires, though. Seems like down here in AZ the tread will crack/separate before the sidewalls. I've yet to wear a set of tires out, they just disintegrate in this 125 degree heat in the summer.
msb
01-02-2008 21:43:38
 Re: Best way to Prevent Tire Checking and Cracking in reply to skyharborcowboy, 01-02-2008 15:03:51
Give them a light coat of silicone spray every 6 months. Silicone is nothing more than microscopic beads of glass and it takes 6 months for them to roll off.Heat the silicone oil up and it will turn into a sheet of glass. The silicone keeps ozone from attacking the rubber amd its the ozone (O2) that oxidizes the rubber. In other words---tire rust-lol,bob Spray it on the kitchen floor and you have a sock foot ice rink of sorts. Its fun to see a little kid try to walk on it in his sock feet.
david b. guest
01-02-2008 20:32:29
Automotive sunblock? They could add that to their advertising. However I got a book today from a Kevin Trudeau that says sunblock causes skin cancers??? How about that??? Seriously don't order the book. It gets you into newsletter and website for additional $20 month which I could not cancel(phone no. over TV) I called my lawyer and she said she got stuck too! I cancelled my credit card, she said thats about all you can do with TV advertising and no address.
showcrop
01-02-2008 18:35:49
I've found that if I overload my trailers by a factor of around two that I get absolutely no checking or cracking of the sidewalls before they blow out or just disintegrate. when using this method though, it's important to always carry a jack, a spare,wrenches, and allow extra time to reach your final destination.
Steven f/AZ
01-02-2008 17:47:19
Have tires that are over 50 years old on tractors with minimal checking... the key is that they are rarely in the sun. The UV rays are what kills them!
Larry D.
01-02-2008 16:38:17
I just simply Keep Tire Covers on them ALL the Time unless I'm actually Camping, Bottom Line as Stated earlier... KEEP THEM OUT OF the SUN.. Larry KF4LKU
J.C.in AZ.
01-02-2008 16:21:10
As I live in Arizona I have found that tires sitting in one spot unprotected for a length of time such as RV Trailers are subject too,Tire failure is a given. I have had a few in this situation go bad [6]before I wised up and started to pay more attention to them.First I quit useing the Trailer type Tire Goodyear and Dealers push RV'Ers to use and went to LT type tires of higher weight ratings and several sizes larger.After a trip I place jack stands under both axles with the tires about 2" off the concrete pad they sit on,I remove each tire and give it a good washing both sides,reduce air presure by 20# each tire and remount them,then give each a good coating of tire coating and I have used Armourall and other treatments for this, then I put tire covers from Camping World on each tire and forget about them until the next trip at which time they are reflated to recommended pressure. A lot of work but I have not had any tire trouble since I have been doing this and it has been 3 years of no problems so far and no sidewall or tred checking is evident.Works for me.
Ken L.
01-02-2008 16:13:48
I have been using 303 Aerospace Protectant. Seems to work well. Seems to bring some of the color back and protect the tires. It says, 100% prevention of UV caused slow-fade with regular use. Good for synthetic and natural rubber. Also Vinyl, plastic, fiberglass & leather. Got mine at the local Toys for Trucks place. Miller tire also has it.
skyharborcowboy
01-02-2008 15:45:08
 Re: Best way to Prevent Tire Checking and Cracking in reply to Jim Johnson, 01-02-2008 15:03:51
I believe that Armour All does add to the problem but I dont know any other brand name of products that may do the trick. Since everyone knows of Armour All I just threw that in there. I know when I took a Scuba Class the instructor said to never use AA on your fins but to use pure silicone product. I dont know if that holds true for Tractor Tires.
Joe
Allan In NE
01-02-2008 15:14:15
Think Armour-All adds to the problem doesn't it?
Just get the tires out of the sun.
Allan
in-too-deep
01-02-2008 15:12:31
Keep them inflated, jack them up to take the weight off, and cover with canvas or something heavy. The UV rays do the most damage. If they're truck-sized tires, go to your nearest RV dealer and get some wheel covers. If they're tractor-sized, go to an upholstery shop and have some nice round covers made. 'Course, it's easy for me to tell you how to spend your money : )
