Tractor Talk Discussion Forum
Old Latest picture of Home Brew Dump Trailer
Oldmax
12-30-2007 16:04:36
third party image
Still working on dump trailer .
Oldmax
01-01-2008 15:25:07
 Re: Old Latest picture of Home Brew Dump Trailer in reply to Oldmax, 12-30-2007 16:04:36
If you wish more details send e-mail to [email protected]
Oldmax
12-31-2007 16:06:24
third party image
Here is picture of dump mech up close . If you want I can e-mail you demsions a 3 1/2 " cyl with 9" travel With 2150 LBS hyd paessure is suposed to lift 2 tons . I made the lift plan to use a electric 12 volt pump . power up , free float down .I used a Cyl & have pump from Lift gate . There is a comercal toper off a utility bed that goes on this upside down for bed . will keep you all up dated on progress .
tn terry t
12-31-2007 11:46:13
 Re: Old Latest picture of Home Brew Dump Trailer in reply to RobMD, 12-30-2007 16:04:36
old max would you happen to have a close up picture of that hoist set up? im workin on a twelve ft dump right now my self i have the bed on hinges already just not sure about the cylinders yet
caterpillar guy
12-31-2007 04:27:10
Looks good. We just put old smaller dump bodies on 2 ton truck frames and cut the frame to make the tounge then hook a PTO shaft for the pump or a hydraulic motor to the end of the pump shaft the valve is run by a rod for the up and down. this way the axles are heavy enough and the springs give a reasonable ride.the tires are usually 8.25-20 or bigger.
ericlb
12-30-2007 20:09:52
nice setup, the hoist setup looks similar to what i have on a 1 ton chevy i own its real handy around the farm, what size is that hydraulic cylinder? it will dump about 3 1/2 yds of gravel, i cant take that much weight on the road in a 1 ton gross weight is 15,000 lbs, but it works here and if i need to road some material i got a nice kw for that
old
12-30-2007 16:53:22
Looking good
paul
12-30-2007 16:29:21
You know, I have a Gehl mixer mill that is sitting in the weeds, would have a nice trailer frame here.... More details on how the hoist will work would be really cool..... ;)
--->Paul
