Tractor Talk Discussion Forum
cam bearing puller
eeeeeeeeeeeeeee
12-30-2007 10:28:22
would this be what i want for removing and installing cam bearings on oliver tractors
Mike M
12-31-2007 05:33:38
 Re: cam bearing puller in reply to eeeeeeeeeeeeeee, 12-30-2007 10:28:22
A good assortment of large flat washers and some all thread 3/4" or 5/8" does a good job and is cheap. You can have made or make a pilot for ones you do all the time. I'd much rather pull them into place than driving on them.
Dick L
12-30-2007 11:23:07
If you have access to a lathe you can make them in minutes. I turned mine out of brass and threaded 3/4" steel rod for the driver/handle. I don't got the nice plastic blow molded box that yall would get for the $143.00 + shipping.
ben brown
12-30-2007 10:56:49
that is the tool i ues and have used it for severl years on all type tractors trucks etc. that not a bad price seem i paid 138.00 i think. its a good useable tool well even install and remove the blancer bushing on jd motors and there small.
Vapet
12-30-2007 10:48:09
Used one of those for years. Works very well. I know of no reason that it wouldn't work on Olivers.
