Tractor Talk Discussion Forum
4020 smoke
Gary Halcom
12-28-2007 15:45:08
My 4020 diesel starts good, and runs good but sometimes it will miss and blow dark smoke out of the stack for a few seconds then clears up and runs fine. I thought maybe I was not running the engine at high enough rpm. Changed fuel filters added fresh fuel with conditioner. Last time I noticed it when going up and incline. Any thoughts, from the pros.
Thanks
Texasmark
12-29-2007 07:02:33
 Re: 4020 smoke in reply to Gary Halcom, 12-28-2007 15:45:08
I had the Roosa Master pump go out once on a 4010. It didn"t do what yours is doing. It just got to where I couldn"t control it; would run at whatever rpm it wanted.
Puffs of smoke, if black, to me sounds of carbon buildup and carbon around the tips of the injectors occurs BTDT.
Additionally, the injector nozzles could be clogging either internally from the fuel, or externally from this carbon buildup. Once you screw up the fine mist spray pattern, you loose BTU"s, hence hp., and you get the black (unburned diesel) smoke.
I"d get something like "Sea Foam", obtainable in pt. cans at most any auto parts store for around $6 a can. It has oil, naptha, and alcohol in the mix and was initially designed to loosen up rings and clean up combustion chambers on outboard motors (for boats) in the colder climates where people liked to troll at low rpm"s and engines were getting all choked up.
I have tried regular diesel treatment and used Marvel Mystery Oil (also a solvent) for years, but even after doing that, when I did the Sea Foam thing things changed.
I use it in everything with an internal combuston engine around the place, everything, and have given all my tractors a "dose of castor oil". The results have been phenomenol. In most of my 40 year old tractors, it has completely cleaned up the exhaust. I recovered lawn mowers, weed eaters, chain saws and outboard motors.
If I were addressing a problem such as yours, I"d put about 3 cans in a tank of diesel (about $20 worth) and just give it time to do it"s thing. Go about your business normally for the most part.
However, it works best if you get it in the engine, give the engine a work out and then let it sit and back and forth. Allowing the engine to sit between operations (like overnight), gives it time to soak into the carbon and loosen it. About every 10 minutes (give or take) of operation, set the throttle to governor limit rpm"s and let her roar. Don"t be surprised what comes out of the stack.
I buy it by the case of 12 and usually ask for and get a 10% discount.
Besides, this is good for your engine, whether or not it solves your problem, it"s easy to administer, and is cheap. Can"t beat a deal like that, and who knows it may work.
HTH
Mark
Gary Halcom
12-30-2007 08:22:14
 Re: 4020 smoke in reply to Texasmark, 12-29-2007 07:02:33
Mark, thanks for the suggestion on the use of Sea Foam. I have used this product, but not in this way.I Have also used the Marvel Oil. I will give this a try. The engine runs strong and smooth and does not always stutter. The fuel filters were,I think overly dirty so this may help. Again thanks to you and the other responders.
Gary
Texasmark
01-01-2008 11:08:03
 Re: 4020 smoke in reply to Gary Halcom, 12-30-2007 08:22:14
This is getting way down the list; page 7 now, you may not catch it, but I have had clogged filters too and you don't get what you described; you just get a tractor that doesn't respond to the throttle and doesn't want to run above an idle.
Mark
msb
12-28-2007 20:58:34
How many hours since the injection pump has been rebuilt ? 3,000 or more? Sounds like it possibly needs it redone.Are the engine speeds steady?Or does it sort of drift? Also check to see if you have good flow of fuel from the tank to the lift pump. Could be partially plugged.
matthies
12-28-2007 18:29:07
If it's a late model, they have an air prefilter above/before the air cleaner that it normally serviced. And alot of people don't know this. chris
LBSMJS
12-28-2007 17:06:12
Your advance in the inj pump might be going out.If your nozzels check out.
RobMD
12-28-2007 16:11:07
Dirty/clogged injectors, possible injection pump setting unnecessarily high.
Gerald J.
12-28-2007 16:37:13
 Re: 4020 smoke in reply to RobMD, 12-28-2007 16:11:07
Or restricted air intake like air filter, intake manifold or precleaner.
Gerald J.
