Tractor Talk Discussion Forum
O/T- I just needed to pass this info. on
RobMD
12-27-2007 17:25:34
To Anyone who may be rebuilding an engine with a computerized mechanical distributor (regular distributor with a camshaft position sensor):
IF using a new AFTERMARKET camshaft, the indexing of the distributor COULD be different from the original, non-adjustable indexing.
Just replaced 300 dollars worth of sensors to repair an erratic running 1995 4.0L chrysler inline six with a fresh overhaul. Turned out that the rotor was about 3/8 of an inch retarded from the number one cylinder at TDC in the preset indexing.
I hacksawed off the non-adjustable hold down and mounted the distributor correctly. Behold, no more running problems!
JoeBob/IN
12-28-2007 11:06:55
 Re: O/T- I just needed to pass this info. on in reply to RobMD, 12-27-2007 17:25:34
Isn't it possible to readjust the timing via a good scan tool. Seems like someone told me you use them to set the timing for most newer cars to get them exact.
Bob
12-27-2007 23:28:45
That's SURE typical of the way things are today.
Heaven help those of us who try to repair and rebuild things... you just NEVER know what you'll run into, anymore.
