Tractor Talk Discussion Forum
12 volt front coil
Gary Alford
12-26-2007 07:50:06
Does anyone know a part number from Napa for this? also wouldn"t a 6 volt coil with a external resistor work?
Gary Alford
12-27-2007 03:48:00
 Re: 12 volt front coil in reply to Gary Alford, 12-26-2007 07:50:06
Cheeze you guy's, I ended up buying a 6 volt made in Twiwan coil from Napa because that is all they sell, none of those guy's at Napa are tractor familiar so they just look at you when you ask for a 12 volt, and I added a resistor to it and will see how it goes. The tractor had already had a 12 volt coil on it, and it fired, but not under compression.
buickanddeere
12-26-2007 19:26:36
 Re: Bob's mythical coils . . . in reply to Gary Alford, 12-26-2007 07:50:06
Where and how did you/do you dig up all this data? What is your background anyways? For some of the rest of you. The newest coils have very low resistance of 0.5/0.6 ohms. Full voltage is applied however the ignition systems electronics keep the dwell time very brief. Just enough time to barely magnetize the core to saturation but without enough duration to cause excessive primary winding heating.
There are still some hotrodders who figure they can make a Blitzburg ignition system by purposely running a 6V/1.5ohm coil on full time 12V. They give ignition component manufactures a pile of grief with bogus warranty claims.
MarkB_MI
12-26-2007 19:20:26
I know better than to jump into the "true 12 volt coil" dispute again, but here I go.
Short version: It makes absolutely no difference whatsoever whether the resistance in a 12 volt points and condensor ignition is external or internal to the coil. And if the resistance is internal to the coil, it makes no difference whether the resistance comes from the coil winding or some resistance element. So, there are no "true 12 volt" coils. There are coils that require external resistors and there are coils that do not require external resistors. Call them what you will.
Now, the long version:
First, make the assumption that all ignition coils have an identical inductance. Now, there are coils that have non-standard inductance, but these are intended for hotrodders using high performance distributors; we are not talking about these coils.
OK, so the spark energy released by a coil is whatever energy was stored in the coil at the instance the points open. That energy is equal to one-half the inductance times the square of the current through the coil. So, if the inductance of several different coils is identical, then whichever coil has the greatest current will have the greatest energy.
But what controls the current through the coil? Well, in steady state it is ohm's law: current equals voltage divided by resistance. We know the voltage applied by the battery is 12 volts. (Actually, it's not; a "12 volt" system is really around 14 volts, but never mind that.) The resistance is the TOTAL resistance from the positive battery terminal to the negative battery terminal. That includes the primary wiring, any external resistor, the resistance of the coil windings, and other resistance in the coil, and a whole bunch of other things such as the points, key switch, splices, etc. So IT DOESN"T MATTER where the resistance comes from, it all gets added up in the end. If the TOTAL resistance is the same, the coil current is the same, and the coil energy is the same.
OK, so someone is likely to say "yeah, but what about AFTER the points open". Well at that instant you have an RLC (resistor/inductor/capacitor) circuit. and yes its behavior is going to vary depending on the resistance in the circuit. But once again it is the TOTAL resistance in the circuit, NOT just the internal or external resistance alone. And that total resistance is going to be the same as it was BEFORE the points opened, with the exception that the points are no longer in the circuit (the current that was passing through the points now passes through the condensor).
OK, flame away.
TractormanNC
12-26-2007 15:41:47
John T, Bob, others comments please.
Many years ago converted a Farmall 130 and an M to 12 volt. Took the easy way out and added a resistor between the switch and coil. Proper polarity on coil terminals and NO solenoid to bypass resistor when starting. Always had trouble starting in cold weather until changed to a true 12 coil without resistor.
Leonard. (also a retired EE)
John T
12-26-2007 16:11:15
 Re: 12 volt front coil in reply to TractormanNC, 12-26-2007 15:41:47
Hi Leonard, Something that could have contributed to the difference is the ohms values of the coil and the ballast resistor you used.
In the IDEAL situation the ballast resistance (around 1.5 ohms) would be near the same as the coils primary (also around 1.5 ohms) such that a true 50/50 voltage divider existed and the coil saw a full 6 volts as designed for. HOWEVER coils varied from maybe 1.25 ohms to under 2 ohms and likewise Ive seen those ballast from 1.5 to 1.85 ohms SOOOOO OOOOO OO when you bought an of the shelf ballast it may have been on one end of the spectrum and if the coil was on the opposite end you may have ended up with a voltage divider that only applied 4.5 to 5 volts on the coil i.e low current and a weak spark. HOWEVER that problems not there on that full true 12 volt coil.
Or else maybe (say the voltage divider left sufficient voltage on the coil) the old coil was simply showing its age and that brand new just yielded more spark gap energy as there were less losses to heat or other inefficiencies.
Fun chat, theres other possibilities but I gotta run, will check back later
John T another olddddd dd lol retired EE
jdemaris
12-26-2007 12:58:37
In reference to internal resistance coils not ever exisiting -
Bob stated: "Can you PROVE you've EVER seen EVEN ONE coil with an INTERNAL RESISTOR, as opposed to simply more windings? I think the idea of the almost "non-existant" "INTERNAL" resistor is REALLY a persistant MYTH "
It's not a myth at all. It used to be common in many systems including Remy, Delco, Atwater Kent, Connecticut,Willys-Knight, etc. Many had a removeble caps that pried off the top of the coil so the resistor could be repaired or replaced without changing the whole coil. The resistors were not there just to preserve point and coil life, they were also there to prevent dead batteries when igntion switches were left on. Here's a description from a 1930s Dykes Auto and Tractor Repair manual:
"The purpose of the ingition resistance unit is twofold, one being to protect the battery from discharging back through the primary winding and thus overheating the winding and discharging the battery if the switch is left on and the engine is not running and the breaker points are closed. The igntion resistance is made of iron wire, usually mounted inside the top of the coil mounted on a porcelain spool. It turns cherry red when the primary current flows through it for any length of time. If current is left on for a long period of time, the resistance may burn out. This sort of thing happens frequently. "
third party image
third party image
third party image
36 coupe
12-27-2007 14:23:34
 Re: Bob's mythical coils . . . in reply to jdemaris, 12-26-2007 12:58:37
Atwater Kent closed his factory in the mid 30s because the workers wanted a union.He made ignition systems for the Model T Ford.It may have gotten power from the fly wheel magneto that put out 8 to 10 volts A.C.My father in law had a T with an Atwater Kent ignition.It gave him trouble with jumping out of time.A.K made some nice radios.
jdemaris
12-27-2007 17:47:35
 Re: Bob's mythical coils . . . in reply to 36 coupe, 12-27-2007 14:23:34
Yes, I've got three including one from the mid-20s. There also used to be an "Atwater Kent Radio Hour show" - way before my time.
Bob
12-26-2007 15:13:23
 Jdemaris's 6-Volt coils from the 30's... OT to THIS thread.. in reply to jdemaris, 12-26-2007 12:58:37
You are showing 6-Volt coils, with resistors mounted on their OUTSIDE, from way back in the OLD DAYS.
I AM well aware of those.
What WAS being talked about in my post was 12-VOLT COILS from the relatively MODERN ERA.
Are you aware of ANY 12-Volt coils from the relatively modern era with an actual resistor INSIDE the "can"?????
jdemaris
12-26-2007 15:59:06
 Re: Jdemaris's 6-Volt coils from the 30's... OT to THIS thre in reply to Bob, 12-26-2007 15:13:23
Granted that putting words together, making sentences, all to get a point across can be a bit inprecise at times. But, as I read your statement, it comes across to me that you claim the entire idea is fictional - not just in recent igntion coils.
You posed the question "Can you PROVE you've EVER seen EVEN ONE coil with an INTERNAL RESISTOR . . ."
You did NOT say one "newer" coil, or one "12 volt" coil.
Seeing how this forum has a primary focus on antique equipment, I didn't think 1930s - 1940s electrical systems were not included in the discussion. Also - about your most recent comment about the images I posted - and the resistors NOT being in the coils? I guess it depends on what you call "in." They certainly were considered part of the coil, but the coil top could be pried off for access to the internals. Go pick up an Oxford English Dictionary and look up the word "in", and I think you'll find it applies here. In regard to 12 volt coils, I have worked on many specifically referred to as internal resistor coils. I have some specs on `1960s - 1970s outboard motors and some British and German cars that go as far as give resistance specs just for the resistor inside the coil - separate from the primary and secondary windings. But, I can't say I've ever bothered to saw one in half just to look inside. Once the tops no longer popped off, I tended to just throw coils out when they stopped working.
How many have you cut in half?
Bob
12-26-2007 19:20:31
 Re: Jdemaris's 6-Volt coils from the 30's... OT to THIS thre in reply to jdemaris, 12-26-2007 15:59:06
I've cut quite a number of coils apart over the years.
AND, I'm beginning to see why you got kicked off the other forum, as you are being needlessly argumentative here.
jdemaris
12-27-2007 08:00:32
 Re: Jdemaris's 6-Volt coils from the 30's... OT to THIS thre in reply to Bob, 12-26-2007 19:20:31
Hey . . . you posted a challenge in regard to the coil, not me.
I am not going out and seeking arguments for intellectual practice. I am also limited by expressing myself with a keyboard and it seems I come across differently to different people. You are the first person that has ever overtly accused me of such on this forum.
If more people other then you, want me off the forum - well, seems for that reason alone - I wouldn't want to be here anymore.
buickanddeere
12-27-2007 11:08:39
 Re: Jdemaris's 6-Volt coils from the 30's... OT to THIS thre in reply to jdemaris, 12-27-2007 08:00:32
That resistance controlled by temperature/watts is a rather simple and clever way to vary "dwell time". JDemaris I'd rather you stick around. You are crusty enough to be entertaining and know enough to be helpful. Somewhat like a Mr. Thinker in a certain magazine.
John T
12-26-2007 13:44:16
Great info jd, as they say "A picture is worth a thousand words" The few I recall seeing (and I mean fewwwww ww) that I suspected had an internal discrete resistor had a prounounded ring/groove about 1 inch or more down from the top that looked like a seperate compartment. Still in years and having been a used tractor dealer I never ran across anyyyyy that looked just like your neat picture and would still say the majority of the non ring or non your picture type 12 volt coils (what some call internally ballasted) DO NOT have such an internal pure resistor but either more wire length/turns or more resistive wire in order to come up with the resistance sufficient to limit points switching current to around 4 amps to avoid premature burning.
Again, GREAT PICTURE n thanks for more info, we (or us sparky types) got a lot of mileage out of such a simple but interesting lil coil question.....
Happyyyyy y Newwwww w Yearrrrr rr Yalllll lll
John T
John coil
12-26-2007 19:44:11
 Re: Bob's mythical coils . . . in reply to John T, 12-26-2007 13:44:16
Free Image Hosting at allyoucanupload.com
jdemaris
12-27-2007 08:07:41
 Re: Bob's mythical coils . . . in reply to John coil, 12-26-2007 19:44:11
Hey, I think I see a separate resistor inside that coil-image you posted. Are certain people gonna' say you need to be banned from this forum too??
jdemaris
12-26-2007 18:21:19
I've always wondered how a modern coil would work if it does indeed have a resistor separate from the primary and secondary windings. Makes little sense to me unless it is spark-need sensing and can vary resistance. A heat-sensitive resistor does that just fine, many Fords use them externally. I have read though endless patents of transistorized resistance units also that can vary with demand.
I never gave this much thought before this - since I like having an external resistor so I know what I've got, and I know I can bypass it when needed.
Jerry/MT
12-26-2007 12:53:28
NAPA IC-14SB ~$15.
IH2444
12-26-2007 10:18:21
TSC has 8N coils I believe.
and all 12V coils I have seen have an internal resistor, not more windings. Seems if more windings they would be twice as big ?
John T
12-26-2007 11:06:24
 Re: 12 volt front coil in reply to IH2444, 12-26-2007 10:18:21
IHC, To the contrary, other then the ever so slight possiblilty Bob and I referred to below, IVE NEVER SEEN OR KNOWN (notwithstandign the few exceptions) STANDARD COILS THAT CONTAINED ANY INTERNAL DISCRETE BALLAST RESISTOR. Like I posted below in my description of the design and engineering concepts of 6 and 12 volts coils, the necessay added low voltage primary resistance is achieved EITHER by more wire or higher resistive wire use.
Hope this helps yall
God Bless n Happy new Year
John T Retired Electrical Engineer
Bob
12-26-2007 10:26:58
IH2444,
I think the idea of the almost "non-existant" "INTERNAL" resistor is REALLY a persistant MYTH.
Just because the coil is marked "NO external resistor required" does not mean there's a DISCRETE resistor inside, just more primary turns.
By FAR the most space inside a coil is taken up by the SECONDARY windings. The PRIMARY winding, which is what we are concerned about here, takes up a small portion of the space inside an ignition coil, and there is PLENTY of room for increasing the number of primary turns.
36 coupe
12-27-2007 01:58:33
 Re: 12 volt front coil in reply to Bob, 12-26-2007 10:26:58
I doubt there is space in side the coil can for a resistor.The heat from an internal resistor would be bad for the coil.You would use more turns of a finer wire if you increase the primary voltage.This would increase the resistance and keep the current at a lower level.
RobMD
12-26-2007 08:18:56
Huh? For what application? A 12 volt coil with external resistor Is used on some applications to reduce the voltage to the coil to about 6 volts. Never did really understand why the engineer would need to add a resistive load to lower the voltage in a 12v system.
buickanddeere
12-26-2007 11:58:39
 Re: 12 volt front coil in reply to RobMD, 12-26-2007 08:18:56
Because the bypass starting circuit applies full electrical system voltage to the 6V coil while cranking. Once the starter is released the coil is supplied 12V through the resistor which limits current to approx 4.0 amps.
Gerald J.
12-26-2007 10:11:52
NAPA would be the last place I'd be looking for that non original 8N coil.
I see val blt shows a 12 volt coil for the 8N in their 2006 catalog. Might be YT has such a thing.
A 6 volt coil with a resistor the same resistance as the coil primary will work well on 12 volts.
There's another reason for a resistor and fewer primary turns. Not important for a tractor, but for high speed engines, the inductance slows the current rise and the low inductance coil with the current limiting resistor allows a faster current rise and so higher speed engine operation. Some hot 6 volt Chrysler products used a 3 volt coil and a resistor for that reason.
Gerald J.
georgeky
12-26-2007 09:14:28
Because all coils are really 6 volt.
John T
12-26-2007 09:47:20
 Re: 12 volt front coil in reply to georgeky, 12-26-2007 09:14:28
George, Actually, there are indeed 6 VOLT COILS and then there are 12 VOLT COILS and NOT ALL coils, therefore, are 6 volt. Heres the difference:
6 VOLT COIL
Has around 1.5 ohms of low voltage primary winding resistance as measured between its lil + and - terminals.
It is engineered and designed for ONLY 6 volts use and 12 volts would cause it to overheat plus the points would burn up quickly from switching excess current!!!!
12 VOLT COIL
Has around 3 ohms of primary coil/winding resistance as measured between its lil + and - terminals and is designed to have 12 volts (NOT 6) applied across its terminals.
If you were to only use 6 volts it will have a weak spark !!!!!
Although some refer to them as being "internally ballasted" most (slight exceptions) achieve their higher 3 ohms of primary resistance by use of more turns or length of primary coil windings OR ELSE they could use higher resistance wire.
One reason for 6 volt coils to have only 1.5 ohms of low voltage primary winding resistance while a 12 volt coil has twice that (around 3 ohms) is to limit the amount of current necessary for the points to switch to around 4 amps to avoid premature burning.
If you wish to use a 6 volt coil on a 12 volt tractor you can add an external series voltage dropping (12 to 6) ballast resistor so the coil only sees 6 volts plus the current the poinst have to switch is again reduced/limited to around 4 amps to avoid premature burning. One advantage of such a system is so the externally ballasted system (NOT so if theres no external resistor as on a 12 volt coil) can by by passed during start up to improve cold weather starting.
Hope this helps yall understand the 6 volt and 12 volt coil thing.
God Bless n Happy New Year
John T
Bob
12-26-2007 09:28:42
George, WHERE did you get THAT idea???
There's all sorts of 12-Volt coils, which, contrary to popular belief, are simply wound with more turns in the primary winding, and, with very few exceptions do NOT have an "internal resistor", just MORE windings.
georgeky
12-26-2007 16:25:24
 Re: 12 volt front coil in reply to Bob, 12-26-2007 09:28:42
Well Bob, and John T, that is what old electric service folks use to tell me. I was always told the only difference between 6 and 12 volt coils was the resistor. If that is not so, thanks for clearing it up.
John T
12-26-2007 10:09:02
Funny that we BOTH used the word "exception" I used it cuz years ago I recall some 12 volt coils that had a ring at the top about 1 inch down with that appeared to be a seperated internal space at the very top where perhaps??? a discrete pure ballast resistor was housed???? WE may have to dig out some old cutaways n see just what they hid in there lol
Hapy New year
John T
KEB1
12-26-2007 08:24:32
Because in automotive applications there's an extra set of contacts on either the key switch or the starter selenoid that bypasses the resistor for starting. Gives a hotter spark for starting, then reduces current when the engine is running to make the coil & points last longer.
Keith
Bob
12-26-2007 08:21:33
Rob,
He's looking for the NAPA # for a 12-Volt "square-can" coil for the "front-mount" distributor on a Ford 9N/2N/Early 8N tractor.
