Tractor Talk Discussion Forum
E350 won't start
ford man 123
12-18-2007 20:35:02
I have a 95 E350 it cranks it just wont start the battery is good im just not much of a mechanic
thanks in advance
El Toro
12-19-2007 07:08:58
 Re: E350 won't start in reply to ford man 123, 12-18-2007 20:35:02
You should buy yourself one of those code readers
they can pinpoint the problem if there's a code stored. They're not that expensive. Hal
jhill52
12-19-2007 04:53:31
Can you hear the fuel pump run when you turn the key. If not check the fuel pump impact switch under the dash. There is a red reset button to push. The owners mmanual will have more info.
Pete in Cal
12-18-2007 23:29:25
E350, give us some more details such as gas or diesel engine, how it ran when you last used it and so on. Pete
