Tractor Talk Discussion Forum
Need help Farmall 806
Brad J
12-18-2007 15:09:53
I have a Farmall 806 and the 3 point hitch is stuck in the load control pre set position how do i fix
Allan In NE
12-18-2007 15:16:12
 Re: Need help Farmall 806 in reply to Brad J, 12-18-2007 15:09:53
The handle is stuck?
Have you tried loosening up that clutch bolt at the base of the lever?
Allan
Brad J
12-20-2007 08:16:37
 Re: Need help Farmall 806 in reply to Allan In NE, 12-18-2007 15:16:12
Yes I check that first. I took of the top plate and everything seems to be moving. I wounder if a vlale or ball is stuck in side. I do not have a service manual, would someone fax me or e mail be some info. on that section Thanks Brad hope I do no have split the tractor .
