Tractor Talk Discussion Forum
OT Oil Gas Mix on Snowmobile
Nebraska K
12-18-2007 11:53:13
My brother has a 1976 Massey Ferguson Chinook snowmobile and we were wondering if anyone new what the oil/gas ratio is supposed to be?
Thanks
Nebraska K
135 Fan
12-18-2007 22:20:16
 Re: OT Oil Gas Mix on Snowmobile in reply to Nebraska K, 12-18-2007 11:53:13
With a good oil, 20-1 will be too much. Don't mix standard and synthetic oil. Some synthetics can run up to 100-1 but most people will run them about 50-1. Optimal is a very good non synthetic oil and I run it at 50-1 in a racing two stroke moto-cross bike. Many others do as well. I have run Castrol 2 stroke oil before at about 40-1. I have run my bike in a few six hour ice races and never had an oil related failure. Oils have gotten a lot better since the 70's. Dave
Nebraska K
12-18-2007 17:35:26
Thanks for the help guys!!
Tim in NB
12-18-2007 17:34:36
1976 masseys were made by Scorpion. The Massey Chinook 300 with the Cuyuna 294 CC engine wants a fuel oil mix of 20:1. From the service manual: Use regular gasoline and a two stroke motor oil meeting Mil. Spec. 2104-A (Massey Ferguson 841-614-M1 or equivalent. The Scorpion Lil' Whip which is the equivalent Massey snowmobile says 20:1 using premium gasoline and an approved branded snowmobile oil. It also says, however, that lead-free fuel should not be used.
SDE
12-18-2007 15:57:50
I believe that the oil that you use, should be mixed according to IT'S recommended ratio and not by what the machine manufacturer states. After all, they do not know what oil you are using.
SDE
TomTex
12-18-2007 15:05:36
I would use a high quality name-brand oil that says 50 to 1, but then mix it at 32 to 1. Tom
Steven f/AZ
12-18-2007 13:59:53
Older stuff likes 20:1... I leaned one out a bit and seized a main bearing... not fun to repair.
Michael Soldan
12-18-2007 13:29:42
I have a Chinook amongst my collection of Massey Fergusons, I need to get it going one of these days. As far as the mix for those older machines, a quart of snowmobile oil in 5 gallons..if it smokes a lot you can cut back on the oil, but I'd rather have it smoking than running dry and seizing up
buickanddeere
12-18-2007 15:09:15
 Re: OT Oil Gas Mix on Snowmobile in reply to Michael Soldan, 12-18-2007 13:29:42
Excess oil can cause detonation which will ruin an engine faster than insufficient lubrication. The extra oil tend to lean the mixture which causes higher temps and increases the tendency to detonate. Oil also has a very low octane rating compared to gasoline. So the extra oil also causes detonation due to it's chemical properties. Damage from detonation and insufficient oil can look similar. Scored cylinder walls and ruined rings can either be lube or detonation problems. Broken rings, ruined ring lands, signs of excessive heat are caused by detonation. Another reason to run premium fuel in your two stroke engine.
bill mart
12-18-2007 15:51:42
 Re: OT Oil Gas Mix on Snowmobile in reply to buickanddeere, 12-18-2007 15:09:15
you lost me, could you explain what too much oil does to the cylinder temps. I can see the higher ratio of oil leaning the fuel mixture, but wouldnt the extra oil not burn as well as gas effectively lowering the combustion temps (Detonation aside)? Thanks, Bill M.
buickanddeere
12-18-2007 19:44:55
 Re: OT Oil Gas Mix on Snowmobile in reply to bill mart, 12-18-2007 15:51:42
Still stuck with the detonation problems of the lube oil's low octane. Detonation subjects the engine's components to elevated heat and pressure levels it was not designed to under.
HeyPigFarmer
12-18-2007 12:23:04
On a sled that old when they came from the factory they recommended 20:1 gas/oil. That is a bit thick for the modern oils that are out there. Unless you plan on racing it you can get away with 40:1 just fine.
Anymore with the modern oils you can get away with a lot less oil than you used to. The last motocross bike I had was a Yamaha YZ250 and I ran Belray H1R synthetic at 100:1 and never had one burn down.
