Tractor Talk Discussion Forum
ford 801 3 point lift
ken tinlin
12-18-2007 05:12:49
i have a ford 801.the 3 point has stopped lifting to proper height.oil level is ok and lift does not surge or pulse.my book tells me we need special tools to re adjust.is there a simple way without special tools.any help appreciated thanks
Keith-OR
12-18-2007 13:07:07
 Re: ford 801 3 point lift in reply to ken tinlin, 12-18-2007 05:12:49
Ken, adjustments "can" be made without the special tools. If you read your service manual closely, it will give instructions on how to secure the lift arms in position(without special tool) so they don't move while making adjustments. Also the measurements of gage thickness(gage required)that you need to make the adjustments.
If you need the thickness of the gage, email me.
Keith & Shawn(Special Olympic Champion)
Texasmark
12-18-2007 06:24:58
The special tools they refer to is primarily a forked clamp hootus that positions the lift arms with respect to the cover so that you can get the correct dimensions THE FIRST TIME on the draft spring tensioner. I have setup several by swag and have ended up close enough to be satisfied with it.
Before you jump to conclusions (that you have a problem), what is the position of the DRAFT-LIFT lever on the right side of the tractor under the seat? I think it is supposed to be down for lift and horiz for draft....but it"s been a long time and I forgot. If in draft, the lift has limited range as you move the lift lever through it"s range. I think the words are protrusions on the casting so you can see which is which by looking at it. If not, just put it one way and watch your lift arms and then move it the other and do it again. You will know when you are in the lift position.
Unless you broke something, I don"t recall that they just all of a sudden decide to not go all the way up or down, especially if it functions normally in other parts of the lift range.
HTH
Mark
