Tractor Talk Discussion Forum
RE: Getting Block Bored
super99
12-17-2007 14:17:35
Last saturday I went back to auto parts/ machine shop to talk to them about bringing block in to get checked before I ordered pistons, and told shop man that I had checked at the counter and they said they couldn't get pistons, so I'd have to get them somewhere else. He said to go back out and talk to Tony and have him check, so I did. He said to check back Monday, couldn't find anything on Sat. Stopped in tonite after work and checked with Tony. He can get pistons, rings, and pins and keepers for $185/ hole. Gasket set for $70. Can't get bearings or bushings for wrist pins if needed. That's cheaper than I had found anywhere else, so I told them as soon as I get the block out, I'll bring it in and let them have at it. Guess it pays to check back with the older guys that know what they are doing. Chris
Kansas Cockshutt
12-18-2007 06:10:27
 Re: RE: Getting Block Bored in reply to super99, 12-17-2007 14:17:35
Did I read that right- a machine shop that can"t turn their own bushings if needed?
It"s always good to save money persistance paid off congrats!
Walt Davies
12-18-2007 08:15:30
 Re: RE: Getting Block Bored in reply to Kansas Cockshutt, 12-18-2007 06:10:27
An automotive machine shop usually only has the machines to rebuild engines so yes they may not be able to make a bushing.Of course that may not be correct at all shops so look around.
Walt
Kansas Cockshutt
12-18-2007 12:04:27
 Re: RE: Getting Block Bored in reply to Walt Davies, 12-18-2007 08:15:30
True, I just thought machine shop = lathe and mill at the minimum, in addition to surfacers and hones etc etc
Walt Davies
12-18-2007 08:17:50
Forgot some young friends of mine are building up quite a machine shop and could maybe make any part that you need. Let me know and I will get you in touch with them.
Walt
35A
12-17-2007 16:10:16
Theres no length a parts man won't go to to avoid the real labor of thinking
Mike M
12-17-2007 19:27:09
 Re: RE: Getting Block Bored in reply to 35A, 12-17-2007 16:10:16
You should try being one sometime !!!!! !!!!!
Not everyone coming in the door has a clue what they are doing either !!!!! !!!!! !!!!! !!!!!
Dave Sherburne NY
12-17-2007 15:02:16
You don't live in New York do you? I went to Wis.
to get Piston pins. Even th machine shop couldn't find them.
super99
12-17-2007 16:41:52
 Re: RE: Getting Block Bored in reply to Dave Sherburne NY, 12-17-2007 15:02:16
Western Illinois, parts store is in Iowa.
J Schwiebert
12-17-2007 18:44:54
 Re: RE: Getting Block Bored in reply to super99, 12-17-2007 16:41:52
What are you working on? J.
super99
12-18-2007 01:30:57
 Re: RE: Getting Block Bored in reply to J Schwiebert, 12-17-2007 18:44:54
JD 70 gas. Top ring groove on both pistons are burned out. Chris
