Tractor Talk Discussion Forum
Mixing Calcium chloride
Super Steve
12-17-2007 08:39:07
what is the water to calcium flake ratio for mixing this stuff? And how much would it take to fill a 23x1050x12 tire. I cant find wheel weights for my riding lawnmower so im going this route. Also im no math expert and im sitting here trying to figure out what is cheaper. A 88lb bag of calcium flakes costs about $30, a gallon of windshield washer fluid costs $2 and a gallon of straight antifreeze costs $10. Which is the cheapest and/or easiest way to go? Thanx in advance Steve
Red Dave
12-17-2007 12:35:28
 Re: Mixing Calcium chloride in reply to Super Steve, 12-17-2007 08:39:07
Here is a link to a page with all the information you want.
Dan67
12-17-2007 10:41:46
I added 7 1/2 gal of eco frendliy anti-freeze to my rider and it works great.
Lou
12-17-2007 10:25:26
Window washing solution about $1.50 per gal, tool from Gemplers about $25. and a pump that goes onto a drill, saves lots of $$$.
mike
12-17-2007 09:46:05
4# ca cl per gallon water will give you a 30 below freeze mix. fill the barrel of water 1st then add the ca cl. I have 26 12 12 on 2 of my cadets and I guess they take maybe 10 gallons per tire. Makes a bunch of difference in traction
Got couple hundred gallons on the big truck already mixed up. Bring your tires by and I'll load em for 15 bucks a tire.
mike in NY
old
12-17-2007 09:15:52
Yep wiper fluid or anti freeze is better for what you want then the CACL. I did that years ago on a riding mower because I was cutting grass on hills and it made a very big difference
IH2444
12-17-2007 08:56:35
For riding mower tires just mix up some safe RV type of anti freeze/water mix. Eco friendly and won't rot your rims so bad.
I used the antifreeze type of winshield washer fluid in my riding mower tires.
I got my WW fluid on sale for .89/gal though.
