OT:6.5 Chevy diesel
Tx Jim
12-14-2007 09:21:58
I have a 2000 pickup that has started idling at 1200 rpm's instead of 700. It has 140,000+ miles on it. After it warms up to operating temp it slows to normal rpm's. Is pump controlled by computor? Does pump have a govenor in it like older pumps? Thanks,Jim
Tx Jim
12-15-2007 03:38:27
 Re: OT:6.5 Chevy diesel in reply to Clint Youse MO, 12-14-2007 09:21:58
Thanks for replies and I forgot to say I had it scanned by a local mechanic. No fault codes showed up,only thing funny was as engine speed increasd scan tool showed rpm's falling. Thanks,Tx Jim
Bob
12-14-2007 10:12:20
 Re: OT:6.5 Chevy diesel in reply to Tx Jim, 12-14-2007 09:21:58
The 'puter controls EVERYTHING... fuel rate, advance, idle speed, and max speed.
You need to get a scan tool on it, and take a look at what the 'puter is seeing for coolant and intake air temperatures. It sounds like it "has the shivers", 'cause it's being told the air or the coolant is colder than it really is.
Obviously, check for trouble codes, as well.
Stumpalump
12-14-2007 11:27:03
 Re: OT:6.5 Chevy diesel in reply to Bob, 12-14-2007 10:12:20
Good place for 6.5 help
tiresntracks
12-14-2007 16:26:48
 Re: OT:6.5 Chevy diesel in reply to Stumpalump, 12-14-2007 11:27:03
Its probably just the computer speeding the idle up to help the engine warm up faster in the cold weather. My diesel pickup does the same thing. If its not that cold where you are, then its probably a bad sensor like Bob said.
