Tractor Talk Discussion Forum
One way hydralics. Are they pump friendly?
Allis chalmers
12-12-2007 23:46:53
Hey yall. I bought a 990 international 7foot haybinde. It has one lift cylinder and it is one way hydralics. Is one way hydralics good for my 185 allis hyd pump? Some people tell me they are fine others say I will be buying a new pump. Appreciate help on this one. Thanks in advance
massey333
12-13-2007 05:09:57
 Re: One way hydralics. Are they pump friendly? in reply to Allis chalmers 6, 12-12-2007 23:46:53
On your 185,just hook the hose to the raise (up) outlet and when you want to lower just push the lever on past the lower detent into the float mode and everything will work perfect.That is the way it is designed to work.Don't let some people scare you out.
Tradititonal Farmer
12-13-2007 04:42:49
I use a single cylinder on my 180 with no problem for the last 20 years
Rich Va
12-13-2007 04:36:09
Sunny,just make sure the lever that operates the remote valve returns to the center position after the implement is lowered or raised. This is true with double acting cylinders also.
gene bender
12-13-2007 04:12:21
Pumps make pressure and CONTROL VALVES control the output either one-way or two-way. PSI and GPM are determined by the pump.
Jack a
12-13-2007 03:54:25
Go ahead and use it. No problem.
Big Hunter
12-13-2007 02:42:18
I'm pretty sure your hydraulic pump pumps all the time, so it doesn't care if it's one way or not.
135 Fan
12-13-2007 00:04:00
It depends on the type of valve you have. Dave
Ken Macfarlane
12-13-2007 06:45:18
 Re: One way hydralics. Are they pump friendly? in reply to 135 Fan, 12-13-2007 00:04:00
I don't have a float detent on mine so when lowering I can just touch the lever enough to connect the cylinder pressurized port to drain but the unused port doesn't let have the open centre flow diverted to it.
If I throw the lever the whole way it will put the pump into relief and kill enough hp to slow the tractor down a few rpm's.
