Tractor Talk Discussion Forum
Frozen power steering
lonesomepine
12-04-2007 07:47:09
I have a IH 1466 that has a problem with the power steering freezing when the temp gets down to less than 32 degrees. I have replace the hydraulic fluid and filter, but still have the problem. The loader hydraulics still work, so I put the bucket down to raise the front end, then work the steering wheel from lock to lock. After about 5-10 minutes it will finally free up. What can I do to eliminate this problem besides moving to Arizona?
Allan In NE
12-04-2007 11:11:51
 Re: Frozen power steering in reply to lonesomepine, 12-04-2007 07:47:09
Does it make a "buzzing/singing" sound while this is going on?
Allan
lonesomepine
12-04-2007 11:40:09
 Re: Frozen power steering in reply to Allan In NE, 12-04-2007 11:11:51
No, there are no noises other than the hydraulic pump. The steering wheel turns really stiff, and the wheels will move but very very slow.
Allan In NE
12-04-2007 11:58:36
 Re: Frozen power steering in reply to lonesomepine, 12-04-2007 11:40:09
Your symptom just 'sounds like' a plugged filter/water (ice) in oil/plugged by-pass screen.
However, if you've already done all that something else must be causing the difficulity perhaps in the proportioning end of that front system. Assume your brakes and T/A go south at the same time?
What I can't figure out is why is it only when it is cold?
Did you get all that 20-25 gallons of oil changed? Or, just partial?
Allan
