Tractor Talk Discussion Forum
farmall cub
javan
11-30-2007 16:45:36
I bought a farmall cub w/o battery. haw do i know if it is a 6volt or 12 volt? positive or neg ground? right now the battery cable ends show that it should be a pos. ground. Also it does have alternator and lights
john *.?-!.* cub owner
11-30-2007 19:45:30
 Re: farmall cub in reply to rrlund, 11-30-2007 16:45:36
They did make 6 volt alternators, but they are rare and never came on cubs. Most likely it is a 12 volt neg. ground.
JK-NY
11-30-2007 17:29:39
 Re: farmall cub in reply to javan, 11-30-2007 16:45:36
Is it possible to ck with the person who sold it to you ? If it is an alternator, most likely 12v, generator - 6v or 12v. you could ck a headlamp or the coil for markings whether 6v. or 12v.6v is likely pos ground , ck coil wires.
El Toro
11-30-2007 17:09:50
If its an alternator I think you should pull the alternator and have your local auto electrical shop check the output voltage. They make 6 volt alternators with neg and pos ground. Hal
