Tractor Talk Discussion Forum
IH 756
chrisalma
11-29-2007 20:02:39
Can I put a dt407, 414, 436,or 466 in this tractor I know i will have to extend the frame but will it bolt right up at the bell housing if i use a 66 plate? all info would help
K.B.-826
11-29-2007 20:10:28
 Re: IH 756 in reply to chrisalma, 11-29-2007 20:02:39
Yes, they'll all bolt up to the clutch housing, use 806/856 or 966 flywheel and your clutch will bolt up. 414/436/466 are wider and you'll need to use 66 series frame rails and some sort of spacer plates between the frame rails and front bolster. 407 with 806-1456 frame rails would be a direct bolt-up. All of the tractors with the engines you mentioned are about 3" taller to the top of the hood, so you may have some clearance issues when installing your hood.
