Tractor Talk Discussion Forum
more info
jerry thomas
11-28-2007 04:54:32
i recently posted a message looking for a camshaft for a 284 tractor with a mazda engine. will any other camshaft fit this engine
the tractor vet
11-28-2007 07:27:14
 Re: more info in reply to jerry thomas, 11-28-2007 04:54:32
If you are having a problem with the cam and can not find a new one from Case I H and no GOOD used ones to be found , Then here is some food for thought , Sometimes if ya can find a good machine shop they can weld up the cam and regrind itOr one can start callen Cam companys and they may be able to regrind it back to spec.'s . Also you will need to either have the lifters either reground or replaced with new or it will wipe out the cam in short order .Myself i have never worked on a 284 and do not clam to be the guru on that I H tractor . When i was working on tractors everyday When i did a total rebuild i had the cams either rebuilt or replaced if they were woren . Then i would start looking into WHY it went bad . To soft lobes . wrong oil used valve set not with in spec.'s to stiff springs ????
the tractor vet
11-28-2007 07:28:17
 Re: more info in reply to the tractor vet, 11-28-2007 07:27:14
Wrong spot for this one sorry
