Tractor Talk Discussion Forum
Ford 861 Power Steering Line
Wade Erickson
11-25-2007 12:58:20
My power steering line that runs from the pump reservoir to the steering column has broken and needs to be replaced. The current line is a somewhat bendable metal but it is extremely difficult to get it bent appropriately to fit right. Is there a flexible hose of some sort that a person can use instead of the metal line?
Thanks!!
aFORDable
11-25-2007 17:37:35
 Re: Ford 861 Power Steering Line in reply to Wade Erickson, 11-25-2007 12:58:20
I would think so although I don't know for sure. I had to replace the metal line than feeds the cylinder on my 861 so my brother, who works in a high pressure hose shop, made a rubber one with the correct pressed on fittings and it works fine. Another option might be to check with a New Holland dealer to see if they can get you a replacement line either rubber or metal that is already bent to shape.
