Tractor Talk Discussion Forum
9n ford motor sounds
Young Bull
11-21-2007 14:07:25
WHen I drive down a moderatly steep grade the mottor sounds like popcorn popping or a rock flying around the inside bottom of the motor. Oil Pump?
noncompos
11-21-2007 16:29:03
 Re: 9n ford motor sounds in reply to Young Bull, 11-21-2007 14:07:25
Now, those are creatively described noises...I just wish I could recall ever hearing anything like that...
Poor humor aside, and seriously: "...drive down...": d"you mean "coast" down, with foot off the gas, the engine acting as partial brake, OR actually driving down, gaining speed or going like a bat out of..you know..
If "coasting" down, is sound cyclic, following engine or wheel revs (regular, faster as tractor speeds up, OR more or less random?
If driving down, it"s immaterial, as you"re gonna kill yourself anyhow (more poor humor!!)
If when you pushed the clutch in, going downhill, the noise didn"t slow down considerably, it sounds like something else, not the engine (pushing the clutch in lets the engine drop to an idle, and engine noises should"ve slowed as engine revs slowed). With sympathy..
Haywood
11-21-2007 14:40:32
1..Drive down the same grade with the clutch pushed in and in nuetrual and see if the noise goes away.
2..Also If the axle pivot pin is severly worn it can allow the radiator to move in the fan area.
3..Engage PTO and see if it stops making the noise while going down hill.
4...Engine could be out of time or the valves out of adjustment or both. Leak in the intake and Exhaust manifold.
5..maybe there is a Rock in your engine :<}
Young Bull
11-21-2007 15:29:06
 Re: 9n ford motor sounds in reply to Haywood, 11-21-2007 14:40:32
I just tried pushing the clutch in and the sound did not go away.
old
11-21-2007 15:36:24
 Re: 9n ford motor sounds in reply to Young Bull, 11-21-2007 15:29:06
Whats the oil pressure like?? Does it go up or down when going down hill?? If it goes down you may have a low oil level or the pick up tube might be bent or loose causeing you to loose oil pick up
Young Bull
11-21-2007 15:42:25
 Re: 9n ford motor sounds in reply to old, 11-21-2007 15:36:24
the oil pressure goes done to 18 pounds appx. from 19 pounds.
Sean Feeney 2
11-21-2007 14:18:54
Are you sure its not just the motor popping a little, maybe a timing issue, or in my case just a 68 year old motor its not running perfect but it runs, hate the cold 40 9n. mine does the same thing
if it working.
