Tractor Talk Discussion Forum
Cutoff wheels
Nedd
11-21-2007 09:55:01
I have an old case tractor on cutoff steel wheels. I need to replace the rubber tire rim section and wondering how to center the spokes and rim? I saw a jig for this a few years back but can't duplicate it. Has anyone done this lately. Just want to get some ideas. Thanks
NE IA
11-21-2007 16:44:42
 Re: Cutoff wheels in reply to Nedd, 11-21-2007 09:55:01
You are welcome to use my jig if you live near NE IA, no charge. It is a tripod with big slotted chanel iron, and big all treaded bolts that go under the rim. It has a large cone in the center to center the wheel. A lomg 1/4 inch rod adjusts outward to the outer edge of your spokes with a washer attatched to hold the cutting torch tip, thus a perfect circle / fit.
The old guys told me that you weld every spoke except the last one, then take a break / let it cool down, then weld the last one, otherwise the weldes will break.
Sorry, I could not explain it better. I purchased it at a auction thirty years ago, and was advised it was a dozen different things after I purchased it. I purchased it very cheap, and was a factory machine.
Steven f/AZ
11-21-2007 13:56:17
Local welding/machine shop?
