Tractor Talk Discussion Forum
Allis 'B' froze motor
Steve Erickson
11-20-2007 02:42:23
This is my second 'B', I have had it just over a year. 2 owners ago it was completely gone through, may have had the engine rebuilt. I use it to move wood and snow (tripbucket). Last had it running in March. 2 weekends ago I tried to crank it, the crank moved about 1/2 inch, oh no!!! Since then I have put in PB Blaster, WD40 and ATF in the cyclinders, also tugged it with another tractor, didn't budge. It ran fine last time I used it, just ran it out of gas. In neutral the wheels turn. Could it be something besides rusted piston/cylinder?
Steve Erickson
11-21-2007 02:19:48
 Re: Allis 'B' froze motor in reply to Steve Erickson, 11-20-2007 02:42:23
Thanks guys, guess I'll empty my can of PB Blaster and get some of that Kroil. I do have a snowblower, but moving wood is gonna suk. This is Minnesota, so not much time left. The way it's stuck I'm betting on pulling the heads next spring/summer, just hope I don't break a bolt.
notadeere
11-20-2007 15:28:13
ATF is way to thick, use the pbblaster or even better if u can afford it i use KROIL good stuff higher cost but good & pull your plugs soak it up then pull your starter & use a bar back & forth off the flywheel dont expect it to come over night soak it a few days & work with it if not that bad u will be up & running in no time if its like anything i get its pull head & oil pan & beat out & cry...
old
11-20-2007 08:13:02
Pull all the plugs out and then try to turn it over. It could be locked up becuase one of the cylinders has fluid of some type in it. Since it did move a little I would try to turn it back wards and see if by doing so you could get it to spin a full tunr back wards. If you do then try the other way again and it may just free up
El Toro
11-20-2007 05:19:51
I would pull the head and see what the cylinders look like. I used a piece of 2X2 oak and a hammer and drove the rods & pistons out. It had set outside since day one from the looks of it.
Hal
