Tractor Talk Discussion Forum
Farmall Cub
Bleedcase
11-19-2007 19:08:26
Im putting the clutch assembly on the flywheel on a cub and when all the bolts that hold the assembly are tight to the flywheel it puts pressure on the forks and compresses the springs. I was wandering if there is supposed to be little spacers between the flywheel and clutch assembly or what is going on. thanks
ScottyHOMEy
11-19-2007 19:40:01
 Re: Farmall Cub in reply to Bleedcase, 11-19-2007 19:08:26
It's doing just what it's supposed to do. On some of the larger tractors, the clutch was held to the flywheel with six bolts, but they tapped things out so that, when removing the clutch, you would take every other bolt out of the flywheel and move it over to a hole that would pass through the cover and thread into the pressure plate to hold it back. That held the tension to make it easier to remove, but more especially to hold the pressure plate back when you went to put it back on. In reinstaling, removing the bolts from their temporary postion allowed the pressure plate to go back to its "rest" position where it applies the pressure needed to turn your tranny under load.
Bob
11-19-2007 19:12:59
How do you think the clutch "grabs"?
