Tractor Talk Discussion Forum
1951 case s coolant drain
rc werden
11-19-2007 08:36:52
Short of removing a rad hose does anyone know did this tractor have a drain cock to drain the rad?
Walt Davies
11-19-2007 10:51:00
 Re: 1951 case s coolant drain in reply to rc werden, 11-19-2007 08:36:52
If its like my SI there is a small hole in the frame just under the radiator where you can find a valve to drain it. I had to to use pliers to open it. hard to see and hard to turn.
Walt
Brian in Ohio
11-19-2007 09:28:31
There should be a plug in the bottom tank that you can take out and drain the radiator.
