Tractor Talk Discussion Forum
fuel issues
Eric Pollard
11-18-2007 20:58:31
I recently purchased a 2N that had been setting for a couple of years. I finally got some ignition problems solved, but now I"m not getting fuel to combustion chambers. I"m getting fuel from the bowl to carburetor and the unit will start briefly with starter fluid. I did a partial rebuild of the carburetor but something still not right. I"m trying to keep my expensives to a minimal until I at least get the unit running. I welcome all and any recommendations.
Eric Pollard
11-19-2007 11:59:10
 Re: fuel issues in reply to Eric Pollard, 11-18-2007 20:58:31
Thank you, I appreciate the advice
Janicholson
11-19-2007 06:30:15
Take the carb apart save the gfaskets, and soak it then blow the ports out with spray and reassemble. JimN
Eric Pollard
11-19-2007 11:59:50
 Re: fuel issues in reply to Janicholson, 11-19-2007 06:30:15
buickanddeere
11-19-2007 07:13:10
For the minimal cost of a gasket set. I wouldn't consider re-using an already compressed gasket and hoping it seals. As for a partial job? Any time I've cut corners or tried to economize. It's comeback to bite me in the backside and cost more in the long term.
Eric Pollard
11-19-2007 12:07:07
 Re: fuel issues in reply to buickanddeere, 11-19-2007 07:13:10
Janicholson
11-19-2007 08:17:27
I agree in every way but two. As we get into fuel costs that cripple the "value" of getting a new set, we will find old ones looking pretty good if they do not leak. If they do, it is usually just the body gasket, and it is easy to replace.
The second is that he indicated the need for reduced expense. JimN
RobMD
11-18-2007 21:01:46
partial rebuild? that's what's wrong with it.
