Tractor Talk Discussion Forum
hydralic filter on woodsplitter
ric1
11-14-2007 03:27:13
i made a woodsplitter about 24 yrs ago i never put a hydralic filter on it its splitt many loads of firewood plus a 2500/3000 fence post over the years now the pump i assume is getting weak it doesnt have the splitting power it used to have should i add a filter this time after i put on a new hydralic pump or not.thanks
in-too-deep
11-14-2007 10:32:14
 Re: hydralic filter on woodsplitter in reply to ric1, 11-14-2007 03:27:13
Any farm store should have a cheap one. If not, try this link:
Jerry/MT
11-14-2007 09:21:46
A hydraulic filter, properly installed, is never a bad idea. The clearances in the pump and the valve are pretty small and tclean oil will make a big difference in the life. That said, 24 years of service, depending on the total hrs of use, sounds like pretty good life for a pump.
El Toro
11-14-2007 04:35:38
third party image
I made this splitter back in 1982 and I used a filter. I copied everything that was on a splitter that I rented. I put a 10hp Tecumseh from a Sears tractor on it. I should've used a 6-inch I beam since I didn't have anyway to temper the 4-inch beam and it became slightly bowed. It sure to took the work out of splitting wood. Hal
Bus Driver
11-14-2007 04:22:13
I definitely suggest the filter. Obviously the suction line to the pump would seem to be a good place for the filter, but it is not. Restricting the intake on hydraulic pumps can result in cavitation. That can quickly damage a pump. The return line from the valve to the reservoir is the recommended location for a filter.
