Tractor Talk Discussion Forum
Fall chisel plowing the corn stalks.
IaGary
11-12-2007 05:10:30
third party image
third party image
I like to fall chisel the corn stalks that I don't run the cattle on.
This Wilbeck chisel covers them pretty well.
Subsoil the bean stubble to leave residue on top. Chisel the corn stalks to help get rid of the stalks.
That's my method of tillage, what do you guys use?
Gary
JMS/.MN
11-13-2007 08:11:46
 Re: Fall chisel plowing the corn stalks. in reply to IaGary, 11-12-2007 05:10:30
White disc/chisel after chopping cornstalks. Disc assembly is on a separate cylinder so they can be raised out of the ground on bean ground.
OliverGuy
11-13-2007 04:08:49
We do the same, rip the bean ground, disc/chisel the corn ground. The Landoll chisel we have looks like yours and works good also. Incorporates the stalks well and gets them going towards degrading well. A pass in the spring with a field cultivator and basket and a way we go!
paul
11-12-2007 21:49:08
Molboard plow the cornstalks in the fall, last 3 years I haven't touched the bean stubble. Used to chisel plow it. Oh, I don't chop the stalks, just plow behind the combine.
In spring once with the field cultivator and plant. Well, put down anhydrous in spring usually, so that is a sorta tillage pass, but not really.
--->Paul
IaGary
11-13-2007 04:37:09
 Re: Fall chisel plowing the corn stalks. in reply to paul, 11-12-2007 21:49:08
I don't chop stalks either.
Sure looks like I do by the picture don't it.
IH heads do a pretty good job of chopping them up.
Gary
Bill(Wis)
11-13-2007 21:50:38
 Re: Fall chisel plowing the corn stalks. in reply to IaGary, 11-13-2007 04:37:09
You fooled me. I sure thought you'd chopped those stalks. That's good! Saves one pass over the field.
JoeBob/IN
11-12-2007 20:34:39
Nothing! Strickly no-till here. Sand, muck, and clay. Been doing it for almost 20 years and yes you can sucessfully no-till clay.
flying belgian
11-12-2007 20:33:50
Boy that looks good. I wish I had an implement like that and enough horses to pull it. I run field cultivator with harrows tied up over bean ground and moldboard cornstalks.
Allan In NE
11-12-2007 15:50:11
Gary,
Explain this to me; a totally foreign concept. Next spring you'll what? Disc it and plant?
Allan
IaGary
11-12-2007 16:53:58
 Re: Fall chisel plowing the corn stalks. in reply to Allan In NE, 11-12-2007 15:50:11
third party image
One trip over with this tool and plant it.
Field cultivator.
Gary
bradk
11-12-2007 16:43:05
Allan, In the spring 'round here,guys like Gary and I usually run thru with a field cultivator with a good mulcher(evener) and plant.Discs around our area are primarily fall tillage tools.~brad
bradk
11-12-2007 16:42:10
bradk
11-12-2007 16:41:11
Eric in IL
11-12-2007 15:17:23
I don't use any tillage in the fall. I strip-till ahead of the corn planter in the spring and drill all the beans no-till.
Gary,
Not to change the subject, but how did the lights work on your combine this year? I think you were the one having some issues with only half of the lights wanting to work last year.
IaGary
11-12-2007 16:59:28
 Re: Fall chisel plowing the corn stalks. in reply to Eric in IL, 11-12-2007 15:17:23
I fixed them and they work but I can't remember what the problem was.
Bad connections I think?
Gary
glennster
11-12-2007 05:50:36
we had lime spread this fall, everything got chiseled under.
Mn Dave
11-12-2007 05:15:24
 Re: Fall chisel plowing the corn stalks. in reply to Pete in MD, 11-12-2007 05:10:30
I use an old DMI chisel plow with just the points in the bean ground, and moldboard the corn ground. My "big horse" is a White 2-135 so I don't have many options, but works on the small acreage I run.
