Tractor Talk Discussion Forum
Detroit 8.2L Diesel
Tweeter
11-11-2007 08:48:52
Im going to look at a early '90's Chevy flatbed truck. It has a Detroit 8.2L diesel in it with around 40,000 orig. miles, Im told it runs fine. What are the pros and cons of the motor?
RodInNS
11-11-2007 10:40:16
 Re: Detroit 8.2L Diesel in reply to Tweeter, 11-11-2007 08:48:52
There are pros?
Well, mabey if it's cheap. As mentioned already, the head issues. Add to that the old Detroit fuel system that leaves a lot to be desired in my mind. I spose if you know where to or how to set them up correctly you're fine...
I'd sooner look for something with Cummins B or C power, and IH DT466 or a Louisville with the Brazilian Ford engine.... Even a 3208 Cat (gasp) would be ahead of the fuel pincher.
Rod
Paul Simmer
11-11-2007 10:40:02
Ran one at work in a 1987 GMC. Just replaced it with around 50,000 miles. Never had a head gasket issue, but replaced several air compressor brackets which were prone to breaking because of vibration. We got to where we carried a spare behind the seat.
ohio
11-11-2007 10:12:24
"detroit"
In name only. Show me one good four stroke V8 diesel.
MN Scott
11-11-2007 19:28:00
 Re: Detroit 8.2L Diesel in reply to ohio, 11-11-2007 10:12:24
8.2 is a four stroke.
ohio
11-11-2007 22:59:46
 Re: Detroit 8.2L Diesel in reply to MN Scott, 11-11-2007 19:28:00
sure is, show me a good one!
RickieBlue
11-11-2007 09:24:55
These motors are prone to head gasket failure..the main reason is because there is no block deck on the top and the cylinders are siamesed..front 2 and the rear 2..these stand alone and just are not conducive to capture a head gasket good enough for durability, and they also move around a little, which also takes its tolls on the gasket.
