Tractor Talk Discussion Forum
D-17 Stuck
njm
11-06-2007 06:13:04
Few weeks ago I thought my motor on my D-17 was seized, but after putting oil to it and finally pulled the tractor I found that what I believe is the clutch is seized. Can that be the case? I put the tractor in gear and the wheels lock. When I ingauge the clutch nothing happens the wheel still won't turn. Thanks for any imput...
wdTom
11-06-2007 17:24:09
 Re: D-17 Stuck in reply to njm, 11-06-2007 06:13:04
Is it getting into two gears at the same time, shifter problem.
njm
11-09-2007 10:23:20
 Re: D-17 Stuck in reply to wdTom, 11-06-2007 17:24:09
I think the trasnmission is good... It goes into one gear at a time. I just might be dealing with a stuck motor?
Howard H.
11-06-2007 13:37:58
I don't know how the "clutch" per se could lock.
Can you turn the engine over by hand with it out of gear??
Howard
njm
11-09-2007 09:01:34
 Re: D-17 Stuck in reply to Howard H., 11-06-2007 13:37:58
Doesn't matter if its in gear or out - the motor still won't move. I was just thinking about the clutch when we "gently" :) pulled the tractor the clutch did nothing when I tried to use it. The tractor was in gear and when I ingauged the clutch the tires wouldn't turn at all. Maybe I have a stuck motor and a clutch issue also. Sorry I've never had this before and without taking things apart I thought I could figure it out....
old
11-06-2007 07:15:45
Starter maybe locked up on the ring gear. By the way you should NEVER try to pull a tractor to get it to turn over or you can/will brake parts in the engine and or tranny. I would pull the starter off and then see if the engine will turn. You can turn the engine with the fan belt or a pry bar at the flywheel. Pull the plugs out because that will make it turn easier. Also by pulling the starter you can get a look at the clutch
njm
11-06-2007 08:02:01
 Re: D-17 Stuck in reply to old, 11-06-2007 07:15:45
Thanks .... Forgive Me :)
