Tractor Talk Discussion Forum
Just when you think all possible tractor questions were aske
Tom Yaz
11-05-2007 10:38:11
Hello All,
I need to know what brands/models of older DIESEL tractors that used a in-line injection pump instead of the what seems to be more common
rotary style pump. This is for a R&D project I am working on.
Thanks
KLS
11-05-2007 20:39:26
 Re: Just when you think all possible tractor questions were in reply to Tom Yaz, 11-05-2007 10:38:11
I have a '53 MM UB with an inline Bosch
Trkr
11-05-2007 18:54:43
Sheppard Diesels had their own inline inj. pump.
Dairy farmer in WI
11-05-2007 17:27:26
all the older case tractors i have havs an inline pump. think case used bosh( spelling?) on everything. most or all of bosh were inlines.
ejr-IA
11-05-2007 15:57:29
Farmall MD,SMD,400,450,W and cats series had inlines.
LenND
11-05-2007 14:18:22
Some Case tractors had inline pumps. I have a 1958 Case 900B with the inline pump.
tractorsam
11-05-2007 13:11:19
The British built grey Ferguson Diesels used an inline pump, also the Perkins that was sold as a conversion kit at the time had an inline pump. Also the Perkins conversion for British Fords (E27N) used an inline pump as well as the New Major and the Dexta. I'm fairly sure the Nuffield tractors had inline pumps on them. The old IH start on gas diesels used inline pumps as well as their British direct start Farmall diesels of the same era. Hope this helps, tractorsam
Fordfarmer
11-05-2007 12:31:29
Some 3 and most 4 cylinder Fords from '65 on use inlines, and I think all Ford 6-clyinders use them. (I think the first Ford 6-cyinder was the 6000 in '61) Most 3-cylinders have the rotaries, and some 4-cylinders do also. No definate reason as to what ones got which, as far as I can tell.
paul
11-06-2007 06:19:23
 Re: Just when you think all possible tractor questions were in reply to Fordfarmer, 11-05-2007 12:31:29
My mid 1970's Ford 4 & 6 cyl diesels have in-line. As you say, I don't know there is any rhyme or reason to which got what....
--->Paul
Walt Davies
11-05-2007 11:46:19
All Cat engines have inline pumps.
Walt
Mike M
11-05-2007 11:30:48
All the old 2 cyl. Deere's from 1949 model R to the last of them built in 1960 had I suspose what you can call inline ? as they had 2 pumps side by side one for each cylinder.
