Tractor Talk Discussion Forum
cab glass
Jim W.
10-31-2007 07:49:13
I receently acquired a 1967 JD 4020 with a "Meade Mfg." cab that has been added on somewhere along the line. The cab itself isn't in too bad of shape, but several pieces of glass (the 2 layer safety type) are broken. I'm understanding that I may just be plain out of luck on this, but would anyone have some info on the topic? Most of the pieces are relatively small and all are flat. Their gaskets have shrunken too, gapping at the corners on the square ones and at the bottom of the curved edge ones. I'm guessing that a gasket/rubber can probably be found, but the glass itself??? Thanks in advance for yer help!
Janicholson
10-31-2007 13:33:37
 Re: cab glass in reply to Jim W., 10-31-2007 07:49:13
To put the glass in, Install the glass into the gasket, then put a thin nylon cord (1/8th inch) into the gasket groove on the outside, one and a half times around the gasket, Spray on silicone spray, have someone hold it up to the hole and use the cord to pull the flange of the gasket over the metal. JimN
K.B.-826
10-31-2007 12:07:35
If you can remove the window frames, take them right to the glass shop, they'll be able to cut the pieces to fit perfect and install them into the frames with new moldings. Then all you have to do is reinstall the frames to the cab.
Jim W.
10-31-2007 11:32:28
Thanks guys....I wuz thinkin' that 2 layer safety glass had to be made up at the factory. I'll be on the horn here shortly.
Rich Va
10-31-2007 09:03:08
Any glass shop should be able to fix ya right up.
LenND
10-31-2007 08:23:38
Yes,any glass shop will make the right one. If you aren't close to one the next choice could be plexiglass at the lumber yard. It's better than no glass but it scratches easy and collects dust like a magnet. I have one on my tractor and it works okay but--.
James22
10-31-2007 08:16:44
Like carpenter stated, not a problem. I've also have a Meade cab on my MM and had to repair a broken glass. A good glass company will be able to do the whole job; ie, replace the glass and provide new gaskets. Be sure to tell them it is the thinner gaskets. My experience is that they may not stock the thin gaskets and need to order them before the job. I later had my cab sandblasted and painted, so it was necessary to remove and reinstall all the glass.
carpenter
10-31-2007 07:56:07
Don't let it worry you. Make a templete out of card board or thin plywood. Glass shops all over the larger cities like radiater shops once where. You might be surprised how resonable. They will help you choose the glass. Mail them or drive them the template.
