Tractor Talk Discussion Forum
O/T Part 2, 1999 Cherokee fuel pump
MF#1
10-30-2007 18:47:58
Thanks to david in mo and Hobo in N.C. got the fuel pressure regulator/filter from Chrysler and ready to get new fuel pump going. This is what makes people pull out the hair, the fuel pump won"t run unless it is jumped through the fuel pump relay connectors in the engine bay. Have tried 4 other relays with no luck(all known to work). Wondering if the ECM/computer has a bad circuit or the moon phase is wrong? Or??? There IS voltage to the sending unit but not the pump.
Thanks in advance!!
david from mo
10-31-2007 14:23:21
 Re: O/T Part 2, 1999 Cherokee fuel pump in reply to MF#1, 10-30-2007 18:47:58
only have voltage for a few seconds at key on and will have voltage while cranking. Don't remember your problem david
Here
10-31-2007 15:02:00
 Re: O/T Part 2, 1999 Cherokee fuel pump in reply to david from mo, 10-31-2007 14:23:21
