Tractor Talk Discussion Forum
Cultipacker- Dunham w/ wooden bearings
G Kennemer
10-29-2007 12:56:38
Where can I get replacement wooden bearings for this cultipacker? I'm beginning to think I may have to make my own!
8N'r--WI
10-30-2007 09:03:15
 Re: Cultipacker- Dunham w/ wooden bearings in reply to G Kennemer, 10-29-2007 12:56:38
www.pobcoplastics.com
These guys probably made the originals that were in your cultipacker. Been in business since 1929.
They will custom make any size for you as well and offer either wood or composite bearings.
Tim
G Kennemer
10-30-2007 09:41:37
 Re: Cultipacker- Dunham w/ wooden bearings in reply to 8N'r--WI, 10-30-2007 09:03:15
Thanks for the lead; not the manufacturer of this particular one but were helpful. May work thru them if all other leads are zero.
deanO
10-30-2007 08:55:04
Don't know how big you're looking for but this link is for some smaller ones. Not big enough for most disc harrows. Might be worth a look.
http://cgi.ebay.com/FARM-EQUIPMENT-WOOD-BEARING-HALVES_W0QQitemZ7610250685QQihZ014QQcategoryZ63967QQcmdZViewItem
G Kennemer
10-30-2007 09:44:46
 Re: Cultipacker- Dunham w/ wooden bearings in reply to deanO, 10-30-2007 08:55:04
Checked it out and following up to see if it may be a source. His were round on the outside. Dunham is octagon shape.
gene bender
10-30-2007 04:00:29
Have you tried DUNHAM as not too long ago they were still avail. I would call them mite surprize you. They can be made with any good hardwood.
G Kennemer
10-30-2007 08:03:19
 Re: Cultipacker- Dunham w/ wooden bearings in reply to gene bender, 10-30-2007 04:00:29
Thanks, heard they were defunct. Do you have contact info?
John M
10-29-2007 16:38:32
We had one up until 8 or 9 years ago. Had my neighbor, who builds cabinets, make some new ones. Dont recall what he made them out of.
JMS/.MN
10-29-2007 21:57:06
 Re: Cultipacker- Dunham w/ wooden bearings in reply to John M, 10-29-2007 16:38:32
Maple.
Leroy
10-30-2007 05:20:36
 Re: Cultipacker- Dunham w/ wooden bearings in reply to JMS/.MN, 10-29-2007 21:57:06
Maple, any other wood will not soak up and hold the grease
G Kennemer
10-30-2007 08:10:24
 Re: Cultipacker- Dunham w/ wooden bearings in reply to Leroy, 10-30-2007 05:20:36
My Dunham actually has a grease fitting in the housing. As i understand, some wooden bearings dont require grease as it attracts dirt/grit which can score the bearing and shaft. Why the conflicting info? Any opinions?
Leroy
10-30-2007 17:12:03
 Re: Cultipacker- Dunham w/ wooden bearings in reply to G Kennemer, 10-30-2007 08:10:24
Around here you always pumped in enough grease that you pushed out any dirt that was in the bearings. Heard some on this site say do not grease disc bearings but do not know how the bearings ever lasted a season.
