Does the carb have a drain plug? if so check it to see if the carb has gas init when it dies. This site sells 2 zenith carbs for the 800 series.. any chance it is one of them? Carburetor, New - With reversible linkage. This Zenith carburetor outperforms the original carbs used on: 600, 700, 800 & 900 series tractors using Marvel Schebler TSX692, TSX577 or TSX551 carburetors. Replaces the following OEM part numbers: EBD9510D, 310746, EBE9510D. Center to center on the 2 mounting bolts is 2 516 inches. Made in USA, 1 year warranty. (Part No: 12566) $196.32 [Enlarge Picture] ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- Carburetor, New - With reversible linkage. This Zenith carburetor outperforms the original carbs used on: 800 series, 900 series tractors 1955-1957 with 172ci gas engine. This Zenith carb replaces Marvel-Schebler TSX706 (supersedes TSX593) and Ford EAF9510G. Center to center on the 2 mounting bolts is 2 38 inches. Made in USA, 1 year warranty. (Part No: 13877) $168.13 Soundguy
