Tractor Talk Discussion Forum
Hyd outlets
DMont
10-28-2007 08:55:17
I have a IH 1086 that has two hydraulic outlets and I have a need for 4. I have noticed some of the later IH "s have 4. Are there any that would convert easily to the 1086. The cabe framework appears to prevent two additionsl sections to the present valve bank. Looking for a workable solution.
Jim Johnson
10-28-2007 09:42:58
 Re: Hyd outlets in reply to DMont, 10-28-2007 08:55:17
My 1086 has three outlets. It's not a problem at all.
The easiest way is to go to a salvage yard and get both ends then make a hose with a swivel in the middle. You need the swivel to make it work.
They make them with factory lines for four outlets but you will not like the price.
Jim
the tractor vet
10-28-2007 09:37:02
On a 1086 they offered a total of three from the factory not you could buy two of them electric valve deals that plug in to your remotes and you can SPLIT one into two by the flip of a toggel switch . Or ya can go on a quest and find a factory three valve set then just buy one electric splitter . Now keep in mind that depending on the year of your 1086 that they had two different hyd. systems one was the old OPEN CENTER and the later ones were CLOSED CENTER .
