Tractor Talk Discussion Forum
Priming the hydraulic pump
ChrisPENN
10-26-2007 16:32:13
I'm getting this IHC 404 ready to run - its been sitting for more than 5 years. I've got the cylinders and all oiled but the pump is dry.
I changed the hydro filter, is there a way to fill the filter canister back up before starting it?
Midwest redneck
10-26-2007 17:34:45
 Re: Priming the hydraulic pump in reply to ChrisPENN, 10-26-2007 16:32:13
I would take of one of the lines (inlet line) and try to slowly turn the pump shaft by hand and get it lubed up and filled with oil before starting, this also makes sure that the pump will rotate without breaking anything. Also let the oil sit in the pump for a while before starting, let that oil soak into the seals, shaft seal mostly. maybe even bench test the pump.
