Tractor Talk Discussion Forum
Case SC starting problem
Dale Ziemer
10-24-2007 20:35:14
My '51 Case SC starts quickly and runs smoothly after a long rest. Then, after running some it is shut off, and it won't start again. Will not fire at all. Plugs are dry, with spark. Some leaking at the carb. What is going on?? This is a consistent problem. I would appreciate any experience with this problem and how you resolved it.
rrlund
10-25-2007 07:40:33
 Re: Case SC starting problem in reply to Dale Ziemer, 10-24-2007 20:35:14
Does that have one of those auto parts store in line automotive type fuel filters in the gas line? If so,there's your problem. Throw it away and put the right gas line back on it without one. They aren't made for a gravity flow system. It's vapor locking on you.
RAB
10-25-2007 06:07:43
As KEH, but, in addition, check colour of the plugs. There may be a crack opening up when hot, allowing air into the inlet manifold. Check valve clearances are correct also.
Regards, RAB
KEH
10-25-2007 04:56:27
Try taking sediment bowl off and see if there is a good fuel flow. If no flow, clean strainer and, with the gas cap off, blow into tank to remove obstruction. This is a temporary fix, permanent fix is to remove tank and clean out.
If good flow at sediment bowl, loosen fuel line at carburator and see if there is a good flow there. If not, remove line and blow out . If still a problem, carb needs work.
KEH
