Tractor Talk Discussion Forum
john deere 880 swather
mike jenezon
10-18-2007 08:43:03
Hi can anyone tell me any thing about a 880 swather good bad or otherwise , 4cyl gas 14 ft auger head . are these belt or hydro drive , do they have any inherant bad problems . thanks mike
codycarver
01-29-2008 18:53:42
 Re: john deere 880 swather in reply to mike jenezon, 10-18-2007 08:43:03
I'm looking for a conditioner for a jd 880 14ft auger header. anybody have any ideas?. Thanks.
4010guy
10-18-2007 17:22:26
JD has made some very good machiney but swathers and hay conditioners wernt one of them.
There wobble boxes like to break and fall off for starters.
If you run your cutters hard in rough ground and rocks like we do out here (nw nd) the repair bills on the JDs will break ya.
I now the dyed in the wool JD boys will say different but i have seen a lot of late model swathers sitting on lots out back that they couldn't give away.
dobber
10-18-2007 12:13:56
They were good in their day and first swather ever saw with a steering wheel also. Just didn't have a cab with AC like later ones we had. We use to have one but never used the steering wheel just the levers. Always had to reset the steering clutches and levers sometimes but it was a partnership machine and other partners abused it not making it easy. Engine and the rest of it ran great for years and did a valve job on it once, water pump and radiator job, tune ups, new carb, just other general maintainance but it was a good machine. Only thing bad I remember was the crimper was a real heavy PIA to get off and back on. Think it had a 180 ci JD engine that was also used on many other JD gas tractors and machines. You can put a later JD diesel in it too if engine is bad.
