Tractor Talk Discussion Forum
Disengaging 4 wheel drive
Tim Hagon
10-18-2007 02:28:55
I've got a 1983 International 845 XLN and having used 4 wheel drive, I can't get it to disengage. Any ideas?
super99
10-19-2007 01:50:32
 Re: Disengaging 4 wheel drive in reply to Tim Hagon, 10-18-2007 02:28:55
Try backing up about 10ft while pushing on lever to disengage. Front wheels turn faster than back, so they build up pressure. Backing up takes the load off and it should come right out. Chris
Walt Davies
10-18-2007 08:42:00
Rock it back and forth gently while pulling on the lever. If this doesn't work you may need to go under and see what is sticking. If it hasn't been used for some time it just might be rust in the linkage.
Walt
Tim Hagon
10-19-2007 00:48:07
 Re: Disengaging 4 wheel drive in reply to Walt Davies, 10-18-2007 08:42:00
Thanks Walt,
Someone said to me that it might be "under pressure" and needs to be disengaged on the move. I'll try it.
