Tractor Talk Discussion Forum
tractor discussion
cody n.
10-17-2007 19:06:11
i have a farmall 504 it looses power going up hills does anybody know what might be the problem?
fixerupper
10-18-2007 07:24:56
 Re: tractor discussion in reply to cody n., 10-17-2007 19:06:11
Does it run smooth while it's losing power or does it start running rough? Jim
Andy Motteberg
10-17-2007 21:05:19
Gasoline or Diesel tractor?
georgeky
10-17-2007 20:52:58
Cody, it could be lots of things. Is it gas or diesel?
Lance in Brenham, TX
10-17-2007 19:12:33
governor would be the first thing to check
Vally Farm
10-17-2007 19:10:45
I'd be looking at compression first. Possible governer or clutch issue, but compression would mostlikley be it. Most other things will show up other ways too. Also check fuel flow. Look at the spark plugs and they should show that. Mike
Gene Davis (Ga.)
10-17-2007 19:09:18
Sounds like it is weak. If you told some more about it some one might be able to make a suggestion.
