Tractor Talk Discussion Forum
JD A unstyled
Nate K
10-17-2007 16:06:18
Hi, I was wondering if anyone can tell me how to find the exact year for my JD? It is a JD Model A Unstyled Serial no is #452191
Thanks in advance for any help!
JPatton
10-17-2007 16:54:49
 Re: JD A unstyled in reply to Nate K, 10-17-2007 16:06:18
Nate K - My book shows 1937 started with number 442151 and 1938 started with 466787. That would make yours a 1937 model. If I am reading my parts book correctly yours should have 10 spline axles. The early unstyled A had 10 spline but went to 12 spline during the 1937 year, I believe 460000 was the first 12 spline axles. I am sure that someone will jump in here and correct me if I am wrong on that break point. You can look to the left of this page under RESEARCH & INFO and find serial numbers as well as a wealth of other information about your tractor. Hope this helps and have fun.
J
Nate K
10-17-2007 17:45:08
 Re: JD A unstyled in reply to JPatton, 10-17-2007 16:54:49
Thanks! I'm new and didn't look as far as I should have. This is a great resource and I am greatful for all the help and the point in the right direction.
Walt Davies
10-17-2007 16:53:42
Nate your tractor is a 1937 in the future you might look on the left side of this forum and go to Research & Info and Serial Numbers to look it up yourself. Could save you a lot of time waiting for someone to do it for you.
Walt
Maark
10-17-2007 16:52:06
You can check your ser# on the left hand column under research and Info.. It's a 37.
