Tractor Talk Discussion Forum
Fuel shut off solenoid for 97 cummins
jaker2
10-17-2007 09:15:04
I've got a 97 12v cummins that has a bad fuel shut off. Where is the cheapest place to get a new one. The dealers want $350.00 for one. Anybody know of any cheap ones?
garymac
10-17-2007 16:21:00
 Re: Fuel shut off solenoid for 97 cummins in reply to jaker2, 10-17-2007 09:15:04
I've had two of these, in both cases the solenoid was good, the harness connector was bad. Three insulated butt splices repaired both.
JD9295
10-17-2007 11:11:54
this is the cheapest ive found them, $159.
This one doesnt have the plug on to fit your truck, they have an adaptor ($18) or they have the solenoid with the plug for $185. I took the plug off the old solenoid and put it on the new one.
They are made by woodward (oem maker)
Tramway Guy
10-17-2007 10:06:45
I think it is made by Woodward Sychro-Start, if you want to try that route...
Bill46
10-17-2007 10:06:00
Jaker...I had one go bad while on the road. I put a pin in the bracket and put a shut-off cable like the old Cummins engines had years ago. Been like that for 5 or so years. Pull to run...push in to stop. If you have a manual you will want to insure it in the lock position when out. If the truck gets bumped and rolls any at all when pushed it...it will start. I put mine in 1st gear and lock it out.
There was an article about this in the Diesel Registry magazine a few months back.
Just my 2 cents.
Tim...Ok
10-17-2007 10:00:35
make sure your fuel shutoff relay is good..alot of the "bad solenoids" turn out to be a bad relay..they may be available now thru parts stores,but when I needed one a couple years ago,only places to get it was thru dodge dealer$$ or much cheaper thru Cummins..
Tim
K.W. in Tx
10-17-2007 09:51:57
If you have a Bumper 2 Bumper Parts store near by they have them for 175.
Solid Junk
10-17-2007 09:39:10
Flea-bay has 'em for about 150.
Joe
